UnderTheSouthernCross
Read the thread above. Your problem is likely to need more than that! An easy fix however.
I’ve read all the posts above and presume you’re referring to also checking the bulb holder contacts in the headlight assembly. I’m a bit confused as to which bulb holder contacts in the headlight assembly I should be checking
