Old May 21, 2025 | 04:27 AM
M.C's Avatar
M.C
Default Ground point around the interior fuse
Hi guys, just bought a 2004 coupe and I’m trying to hardwire a dash cam. Just changed the headliner and thought it would be a good time to install the hardwire kit since the trims needed for that are off.
I managed to set everything in place and even find the necessary fuses, but I am struggling to find a ground. The bolt next to the fuse box is not usable for that and the three coppery looking bolts closer to the door are perfect but they are welded on so no luck there. Are there any other points around the driver’s side that I can use? I looked underneath the steering wheel and pedals but nothing so far.
Thanks
