Old May 21, 2025 | 11:25 AM
  #46 (permalink)
xintersecty's Avatar
xintersecty
Default Re: hesitation during acceleration
Here's the link to my Alarm replacement/removal & drain cleaning post hopefully that will be helpful if you replace or remove the alarm.
Thanks @M60A3Driver I need to follow that and get that alarm out of my car. Alarm is the Battery Killer (dune reference).
I have not gotten back to my car between frustration, schedule, and life. I moved my cars around and started working on it again yesterday. I want it running. At lunch I fired it up and got the right settings for my computer to talk to the ECU. It finally idled and did not shut down. After work I did much more testing. I did drive it around and got the hesitation twice. One of the theories put forward is the accelerator pedal. Here are some screen shots of the output values at idle and at 2500 RPM.
pedal at idle
pedal at idle
pedal at 2500 RPM
pedal at 2500 RPM
Tonight I plan to let it idle and burn off some of the gas in car that has been setting and check the warm up conditions. I wonder if I had a batch of bad gas or possible water.
