Old May 22, 2025 | 10:10 AM
  #49 (permalink)
M60A3Driver
Default Re: hesitation during acceleration
Originally Posted by xintersecty
Good suggestion. I will be doing an oil change this weekend and I will put a can in. I need to remove the damn alarm module.
@M60A3Driver You bought a replacement one (not cheap) and I am curious as to why? Currently I don't see any contravisory in removing it.
Last night I let it Idle for 30 minutes. After my dance lesson with my GF, we took for a drive and filled up on gas. I went around the block a few times and punched the accelerator and few times resulting in "OH MY GOD" from the right seat. It felt good getting my crossfire up to speed.
There's no problem if you want to remove it. It won't affect the car at all. I replaced mine because I'm an original type of guy, I like my cars to be as close to stock as possible. I also like the fact that it chirps when I lock it.
It sounds like your getting rid of that bad gas out of the car. I'll bet you had a big smile on your face when you were hammering the go pedal!
If you're not going to drive your car for a long period of time fill the tank so there's less chance of condensation building up. I used to do that with my Harley every winter or I would run it dry.
