Old May 23, 2025 | 11:22 AM
M60A3Driver
Default Re: stuck in 2nd gear, limp mode, need help asap
Originally Posted by entropy
hello all, im new to this forum, i've been reading post for a while but i recently registered... I have an 04 xfire and my car is stuck in second gear..i dunno what to do..its been parked since the weekend and i'm worried about it....i had it scanned and it was a speed sensor problem, no one has that input/output speed sensor not even the dealership..they say i have to buy a whole new valve body...i wanted advice before doing so and where can i get one that beats the dealer's 400 bucks....the speed sensor are mounted unto the valve body...i'd appreciate some comments..thanks alot guys
You can find an independent shop in your area by using this site: https://www.benzshops.com/
They probably used the wrong scanner. Chrysler has no clue what to do with these cars because they're actually Mercedes mechanically. Mercedes dealers won't touch them because they are badged as Chryslers.
If you tell us your approximate location, there might be someone experienced with Crossfires in your area.
