Old May 23, 2025 | 04:10 PM
Jhigby's Avatar
Jhigby
Default Re: Recommendations selling ‘05 SRT6 Roadster
I was able to check the hydraulic reservoir and it was at the MIN level with the top (manually) up. Other notes that may help:
With the engine running:
  • When I go to put the top up I’m not able to get the back of the top (where the glass is) up and out of the way so I can close the tonneau cover. It’s just me doing it, nobody to assist. If I release the hydraulic pressure and then do it with the engine off I don’t have the same resistance lifting the back part of the top.
  • Theres been a couple of times when when attempting this the tonneau cover locks in the upright position. The only way to get it down is to turn off the engine and release the hydraulic pressure
Regardless of whether the engine is running - I can’t snap the top down into the tonneau cover latch (prior to the full tightening). I have to use the 6mm Allen wrench and move it clockwise to open the latch. Then it will seat and I can do the full tighten down with the wrench. This makes me think there’s a problem with the tonneau latch and related sensor.
Thanks in advance for any additional help!
