Old May 24, 2025 | 11:27 PM
M60A3Driver
Default Re: Died misteriously while driving - any ideas?
Originally Posted by CaptArt
Tried the Amp test, draw pegged the meter (old style analog) so something is definitely shorted. Battery still tests good, so I've disconnected it again. As to the alarm, I had it disabled about a year ago when I met with a group of Crossfire owners in Pasco County. Was having battery drain problems at that time, but had no problems once the alarm was disabled. Car had been driving fine up until this event. My guess is I will have to trace all the circuits to find the culprit. Any advice on where to look, or do I connect the battery and start pulling fuses until I recognize a drop in draw; or, would it be easier to pull all the fuses and check the draw as I add each one back in? Since no fuse has blown, would this method even work? I am aware that chasing a short is a challenge, so I'm trying to figure out the best and most efficient method - other than taking it to a shop that specializes in Mercedes vehicles nearby.
Did you watch the video I posted?
