Old Jun 10, 2025 | 04:36 PM
amx1397
Default re: Erratic Spoiler Fix - Limit Switch Source Identified
Originally Posted by ZERACER
Solder joints are not the only potential issue with an RCM. The relays also go bad.
that is what i have been saying without saying it, and Tj Has a test bench set up that we (Members) do no have.
I use to build aircraft circuit boards, for 8 years, now I no longer own a iron or pin to solder anything, i send
my RCM to TJ. I have seen as many as ten members say they soldered their RCM but it failed again,
and , we say send it to TJ but if you do have a spare RCM U could try iy as the RCM as i have said for about 10
years now the RCM is the blood of crossfire , Good luck and let us know when and how your car was fixed.
enough of my babbling ,,, jim
