Thread: Falt code
Old Jul 3, 2025 | 08:58 AM
pizzaguy
Default Re: Falt code
Originally Posted by Crossfireray
I started my engine day on my 2005 crossfire, and it popped up down by the mileage. It showed looks like a little man running with a 4 digit.
where can I find a list of codes?
Our cars do not display the ECU codes in that window - they SHOULD, but they don't.
You are probably seeing the FSS (Flexible Service System) warning of being past due on oil change/periodic service. If the garage that last changed the oil did not reset the FSS, you will get that alert long before the alert is legitimate.
The owner's manual talks about it, here is a bit on it from "Benzshops", a site sponsored by independent Benz garages:
https://www.benzshops.com/mercedes-f...service-system
But frankly, the owner's manual does a GOOD job of describing it.
YOu can download an owner's manual here:
https://www.crossfireforum.org/forum...ollection.html
