Old Jul 13, 2025 | 11:12 PM
GraphiteGhost
Default Re: TPMS light steady on
Originally Posted by Root66
If the problem persists, (we know it will) I think I'll just deactivate the light as previously discussed. Instead of removing pin #2 from the connector and moving it to the empty hole in position #6, any reason not to just snip the #2 wire? To avoid an uh-oh, what color is the #2 wire?
Please do the next owner a favor by doing the unplug wire & move to empty slot on the connector. Then, after doing it either slip a piece of paper outlining what you did at the TPMS connector spot OR mark the inside drivers side removable panel (at the lamp control, side, space where the door covers when you close the door) and mark the inside of that door covering the fuses at the lamp module. This way, all the next owner has to do is replace the wire into the correct slot and get the right/new wheel transmitters. I'm not a fan of hacking up wiring when it can be done without doing that. Good luck!
