TPMS light steady on
Old Jul 11, 2025 | 02:38 PM
Root66's Avatar
Default Re: TPMS light steady on
Here's a little different wrinkle on this thread: Driving along the other day in my '06 Limited coupe, minding my own business and the TPMS light comes on...I continue on home and let the car sit overnight, next morning I check the pressures and all are right on. Using a borrowed Autel TS408, I check the sensors and three are putting out no signal.
Hmmm. I think I'll just ignore the light and keep an extra eye on the pressures. Light says on for several days and today it goes out while driving. Get home and check the sensors with the Autel TS408 and all four are putting out a correct signal. I don't drive the car every day so this story spans a couple of weeks.
Any thoughts?
Old Jul 11, 2025 | 03:41 PM
Failing batteries?
Old Jul 11, 2025 | 05:10 PM
Wadsworth's Avatar
If you want the system working replace the sensors while the batteries are working. They can only be cloned with a good battery.
Old Jul 12, 2025 | 03:12 PM
Root66's Avatar
If the problem persists, (we know it will) I think I'll just deactivate the light as previously discussed. Instead of removing pin #2 from the connector and moving it to the empty hole in position #6, any reason not to just snip the #2 wire? To avoid an uh-oh, what color is the #2 wire?
Old Jul 13, 2025 | 11:12 PM
Please do the next owner a favor by doing the unplug wire & move to empty slot on the connector. Then, after doing it either slip a piece of paper outlining what you did at the TPMS connector spot OR mark the inside drivers side removable panel (at the lamp control, side, space where the door covers when you close the door) and mark the inside of that door covering the fuses at the lamp module. This way, all the next owner has to do is replace the wire into the correct slot and get the right/new wheel transmitters. I'm not a fan of hacking up wiring when it can be done without doing that. Good luck!
Old Oct 20, 2025 | 03:11 PM
Root66's Avatar
To prolong my tale of woe, the light came on again shortly after my last post as I predicted, tester showed three sensors dead again, today the light went out after 2 months of being on...haven't scanned the sensors. Kinda nixes the "dying batteries" notion.
I'm beginning to believe in gremlins. Instead of deactivating the system, I'll ignore the light, as I've been doing, and will inform any future potential buyer of the anomaly.
BTW, I have access to an OTC Genisys EVO scanner, anybody have any experience with those on TPMS problems?
Old Oct 20, 2025 | 04:48 PM
A nice piece of electric tape should make that light go away.
GraphiteGhost
Aug 30, 2024 09:17 PM
rabatts
Mar 22, 2015 09:32 AM
dan gould
Dec 18, 2013 06:54 AM
Kagen
Sep 8, 2010 09:04 PM
sweldon2
Jun 10, 2008 07:04 PM
