Water in the headlight
Old Oct 24, 2013 | 09:58 PM
maxime75us's Avatar
Default Water in the headlight
Hi All,
I installed MORITOMO HID to notice the next day that I had some condensation inside the headlight.
I also lost this tiny ribber yellow dark elbow rubber hose that is connected to the headlight>
Where can I find a new one.
And Can I open the headlight to remove condensation?
Water is dripping inside
Thank You
Old Oct 24, 2013 | 11:08 PM
robby363's Avatar
Default Re: Water in the headlight
Did you put the rubber caps back on after you installed HID's? There is a kit with the vent tubes you can buy from the dealer. http://www.tascaparts.com/parts/inde...&siteid=213668
Old Oct 24, 2013 | 11:15 PM
maxime75us's Avatar
Thanks a lot.
I did re installed the rubber caps.
But will double check again.
Now I need to clean the headlight inside.
Any ideas? Thank YOU
Old Oct 24, 2013 | 11:43 PM
robby363's Avatar
Here's a thread on how to clean the inside. https://www.crossfireforum.org/forum...-assembly.html
Old Nov 4, 2013 | 10:11 AM
maxime75us's Avatar
Super cool.
Thanks a lot!
Old Nov 4, 2013 | 10:28 AM
Originally Posted by maxime75us
Thanks a lot.
Do you mean clean or dry?
Dry the interior with a hairdryer after removing the bulbs.
Clean as mentioned above.
Old Nov 4, 2013 | 10:51 AM
maxime75us's Avatar
To 180
Can you help to clarify a few things?
So first dry the inside with a hair dryer and then pour methanol to clean the inside headlight?
Right?
Just to make sure.
Thank you
Old Nov 4, 2013 | 11:14 AM
To 180
Right?
Just to make sure.
Thank you
I thought you wanted to dry the inside, but you used the word clean so ....
You may end up with water spots and you may decide to clean the inside as well.
smfrycruzr
Jul 17, 2023 05:33 PM
Franc Rauscher
May 9, 2016 12:04 PM
RacerXofFL
Sep 15, 2015 05:00 PM
cppeabody
Sep 15, 2015 08:43 AM
williammt
Sep 6, 2015 11:23 AM
