p0122 acceleration problem... need help figuring it out
Old Nov 1, 2013 | 02:41 PM
Stoner5432's Avatar
Default p0122 acceleration problem... need help figuring it out
I was driving to work this morning and came to a stop. When i pressed the gas pedal to accelerate it didnt seem to respond till i pressed it all the way to the floor. I pulled over restarted the car and it drove like normal again.Has anyone had this problem before. If so how did yall fix it.
Old Nov 1, 2013 | 03:04 PM
Ottawa John's Avatar
Default Re: p0122 acceleration problem..... need help figuring it out
Did you have a code reader to get this info? Check here for possibilities - P0122 Throttle Position Sensor/Switch A Circuit Low Input - Check Engine Light Code
but also - check your battery for low voltage. I had this happen on a Mazda once - I could hardly drive, but a new battery fixed it right up.
Old Nov 1, 2013 | 03:45 PM
Stoner5432's Avatar
Default
Yes i did use a code reader. Battery is almost new got it in august. Seems like it only happens when i go over bumps or railroad tracks. Im pretty sure it might be the gas pedal going bad.
Old Nov 1, 2013 | 04:29 PM
Having it happen when going over bumps sounds like there is a connection problem somewhere, but it could be the pedal sensor wearing out. I guess that's the next easiest thing to test, so work back from that through a process of elimination. How many miles on the car?
Old Nov 13, 2013 | 06:37 PM
Stoner5432's Avatar
Default Re: p0122 acceleration problem... need help figuring it out
Update....... Changed accelerator pedal out and all is fine now. Literally took 5 minutes to changed.
Old Nov 14, 2013 | 06:28 AM
Ed Mahoney's Avatar
how many miles on your car !!! Now I know where they get the term lead foot !!!!! LOL
Old Nov 14, 2013 | 12:15 PM
Stoner5432's Avatar
78000 miles
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
Apr 28, 2016 02:04 AM
Ed Mahoney
Other Cars Etc
Sep 21, 2015 10:42 AM
waldig
Sep 17, 2015 10:35 AM
davidc90
Sep 6, 2015 10:37 PM
