Front lower control arm bushings
Old Dec 3, 2014 | 10:22 AM
Stevkearn's Avatar
Default Front lower control arm bushings
Where can I get replacement oem style front lower control arm bushing kits?
Any part numbers or crossing part numbers would be extremely appreciated....
Old Dec 3, 2014 | 10:33 AM
Default Re: Front lower control arm bushings
try Rockauto for the 2003 MB SLK320
Old Jul 22, 2018 | 10:40 PM
Cooper7725's Avatar
When replacing the front lower control arm bushings do you have to take the front end apart or can you just drop the two back bolts down and pull the arm down and replace the bushings?
Old Jul 22, 2018 | 11:02 PM
zip439's Avatar
The only way to get those bushings out is to completely remove the lower control arm, and you will need a press of some kind. Mercedes has a special tool to remove/replace those bushings. Most people find it easier to replace the entire control arm than mess with the bushings.
What makes you think the bushings need replacement?
Old Jul 23, 2018 | 10:46 AM
NeedsWings's Avatar
in most cases it is more expensive/frustrating/time consuming to try to replace the bushings instead of replacing the entire arm.
Old Jul 23, 2018 | 07:27 PM
Steve Jr's Avatar
Yea , here's my take (an i have a press) both bushings (Moog) an a ball joint , about $45. 3 hrs of cussing an fussing or $110 for a good upper arm , an drop it in..dang just buy one...lol
All ready replaced both lower ball joints , easy as pie... haven't got around to those lower bushing though... Think I'll buy those arm too...lol
maxcichon
Apr 21, 2021 08:29 AM
Roty135
17
Oct 11, 2018 10:11 AM
07aeroblue
Jul 29, 2015 12:11 PM
Jerrysrt6
Jul 24, 2015 09:15 PM
2004_
Jul 13, 2015 02:04 PM
