Exhaust Leak
Old Mar 13, 2015 | 12:05 PM
Jonnysmooth84's Avatar
Default Exhaust Leak
Hey Guys!
Proud owner of a 2004 with 117k! I noticed a ticking sound for the last several months when it was cold, but seemed to make less noise once it warmed up, and I read this was pretty normal for these cars, so I disregarded it.
This poast weekend I noticed a very pronounced rumbling/vibration under the driver seat when acclerating heavily between first and second gear, but then dispates. I was thinking this must be exhaust related, so I took it to Big Al's who said I had an exhaust manifold leak and a brokem bracket and needed a new Wide Pipe assembly to repalce 3 Cat's and The manifold. He quoted me 1100 dollars to do the work, but I don't think that is causing the rumbling... Thoughts?
Old Mar 13, 2015 | 03:43 PM
AB_SRT6's Avatar
Default Re: Exhaust Leak
Interested to hear what your outcome is. I have a similar sound on the driver's side. Is the manifold removable without lifting the engine?
Old Mar 13, 2015 | 03:49 PM
I am not sure, but I don't think so. I am inlcined to think his noise/vibrating might be the rear end... I wish someone could tell me!
Old Mar 13, 2015 | 04:04 PM
Speedy4x4's Avatar
Default
U can run 2 cats and be legal, where do u live?
Old Mar 13, 2015 | 04:31 PM
I live in Virginia. Has anyone ever experienced anything like this before?
Old Mar 13, 2015 | 11:08 PM
Speedy4x4's Avatar
Default
Lots of ppl remove 2 of the cats and leave other 2, still pass inspection and sounds better.
Exhaust leaks happen, usually is worse when vechicles sit for extended periods of time
Old Mar 16, 2015 | 02:08 PM
Ended up not being Exhaust related. It is the Center/Carrier Bearing that connects both sections of the driveshaft. Chrysler does not stock the part only the entire driveshaft. Used theis link I found in the forum. Hope it works!
Driveshaft Support and Bearing
TerryR
Dec 13, 2019 03:27 PM
minimayhem
16
Aug 23, 2016 07:47 AM
cuziamninja
Oct 5, 2015 10:39 AM
Sep 28, 2015 07:40 PM
williammt
Sep 6, 2015 11:23 AM
