Best HID setup?
Old Jun 17, 2015 | 10:33 PM
chturner's Avatar
Default Best HID setup?
My sylvania high beams suckkkk. Low beams and fog lights are brighter (ain't that something) so I don't even use the highs. So instead of wasting another $20 on bulbs, I am going to install HIDs and be one of those guys that everyone hates for having blue lights. Any suggestions? Never bought them before and a little knowledge wouldn't hurt. Thanks in advance
Old Jun 18, 2015 | 02:20 PM
maxcichon's Avatar
Default Re: Best HID setup?
If they suuuuck that bad-the bulbs may not be seated properly. Make sure of that first? I have 5000K HID's in both low beams and fogs. Very happy.
There are ~ 3000 threads on this. Happy reading bud.
But make sure the high bulbs are rotated correctly before you do anything else? Just sayin'...
Old Jun 18, 2015 | 03:27 PM
chturner's Avatar
My jacka$$ brother assured me that it didn't matter the way they were rotated. I stated that CrossfireForum disagreed and he continued to put them in 90 degrees wrong. Stupid clips make it nearly impossible. I'll try to do some maneuvering with my fat hands and fingers
Old Jun 18, 2015 | 04:01 PM
Just for your information, the set of high beam bulbs are 180' different from the low beams. There is a tab on the bulbs that fit in a groove in the housing. If the lows are in wrong, the highs 180' from them will also be wrong. Its simple mechanics on how the bulbs fit in the housing with the tabs. Good luck on successfully fitting them.
Old Jun 19, 2015 | 12:23 PM
maxcichon's Avatar
I've been able to disengage the clip and rotate the bulb without burning my fingers. The electrical tabs don't get too hot. When you do this-you can see the light pattern. Helps a ton.
Old Jun 19, 2015 | 02:48 PM
chturner's Avatar
Yes im going to try it tonight with the lights on. I'm going to make the switch to HIDS no matter what but it'd be great to have my high beams work correctly until then.
Old Jun 19, 2015 | 06:16 PM
maxcichon's Avatar
When the "Tab" falls into the "Slot", all will become crystal clear!
Old Jun 19, 2015 | 06:47 PM
Mrmiata's Avatar
Thanks for that reminder!
I drove my roadster to CAA6 following Sherri in hers. We normally take 1 car but I hadn't even put 200 miles on mine purchase since and figured I'd take the opportunity and use her as an "emergency wheel/tire" donor if needed rather than take the Avalanche carrying spares. This resulted in the first time I drove her in the dark (dinner run) and drivers headlight shines about 2 feet in front of the car.. LOL.
Old Jun 20, 2015 | 12:48 PM
chturner's Avatar
Well, I was piddling with them last night and got the driver side turned around. It looks good! Then the passenger side had to give me problems (as usual) when my bulb blew up (knew I should've taken the coolant reservoir tank off). Now I have shattered glass in the light socket. Awesome!! Gosh I want HIDs even more now.
Old Jun 20, 2015 | 01:34 PM
chturner's Avatar
I just felt the tab slide in on the drivers side like you guys said it would. On the way to advance right now for another bulb then I can test them on the way home from work tonight
Old Jun 22, 2015 | 01:47 AM
chturner's Avatar
Lights are fixed. Thank you guys. Went off of your advice and put the tabs facing up. Got the knack for light bulbs now
Old Jun 22, 2015 | 08:10 AM
maxcichon's Avatar
There ya go! Another satisfied customer...
Old Jun 22, 2015 | 04:13 PM
chturner's Avatar
Where do I send your payment?
Old Jun 23, 2015 | 02:04 AM
No charge, just pass it along when someone else needs help.
Old Jun 23, 2015 | 07:21 AM
maxcichon's Avatar
Double +1 to that, brother!
xfireohio
Jul 20, 2020 12:03 AM
Adrian_X
Nov 9, 2017 08:49 AM
RojoGTO
Feb 6, 2016 11:14 AM
gp1200x
Dec 6, 2015 12:59 PM
AlbertFattal
Sep 24, 2015 05:03 AM
