Mystery plastic line under battery tray
Old Oct 18, 2015 | 09:45 PM
CrossfireZona's Avatar
Default Mystery plastic line under battery tray
Removed my battery, and the battery tray. Under the tray was a very small dia plastic line running to the firewall. Does anyone know what that line is for? My first guess is that it is a vac line related to the temp control.
Thanks. Tim in Maricopa AridZona
Old Oct 18, 2015 | 09:58 PM
SRQfun's Avatar
Default re: Mystery plastic line under battery tray
Correct, that is the vacuum line to the interior AC controls and vents. Often when people hear a clicking under that dash it is because this has developed either a hole or split from battery acid.
Old Oct 19, 2015 | 08:23 AM
Thanks, that is exactly what happened - discovered a hole in the line.
Old Oct 19, 2015 | 09:49 AM
07aeroblue's Avatar
Default Re: Mystery plastic line under battery tray
I'll have to pull my battery out this afternoon. I've had that clicking for a while and I thought it was a faulty resistor pack. I changed out the resistor pack but no luck.
Old Oct 19, 2015 | 05:44 PM
Had a friend with a coupe come by and her rough idle was caused by that, except the line was broken where it enters the firewall from the manifold. Fixed it with some small rubber vacuum tubing to join the 2 sections.
Old Oct 19, 2015 | 08:45 PM
SRQfun's Avatar
Right after I spliced mine with a vacuum hose I had the actuator for the recirculating flap go and it also caused clicking. That part number for that is A2028001875. That is a Mercedes part number.
Old Oct 28, 2015 | 07:56 AM
Ed Mahoney's Avatar
I also have a loud clicking noise coming from the dash area when 1st starting the car ! Not all the time & last for just 5 to 10 seconds ! Could this be the problem ?
Old Oct 28, 2015 | 01:25 PM
Red Runner's Avatar
I too found this line under my battery tray but I don't know where the end in the engine compartment is attached. I haven't had any operational problems with this line disconnected. So where does it go? Answer: It goes to the manifold on the drivers side next to the throttle body.
See pictures in post 14 for repair.
Old Oct 28, 2015 | 02:34 PM
The end in the engine compartment attaches to the intake manifold.
Old Oct 28, 2015 | 02:53 PM
Ed Mahoney's Avatar
So anyone know why I'm getting the loud ticking noise coming from dash when I 1st start car ? It last for 5 to 10 seconds then goes way but doesn't always do it !
Old Oct 28, 2015 | 03:10 PM
Mrmiata's Avatar
"top - drivers side" from the throttle body..
Old Oct 28, 2015 | 04:41 PM
velociabstract's Avatar
I thought that line was "rat nip" Mine was chewed!
Les
Old Oct 28, 2015 | 04:45 PM
Mrmiata's Avatar
Les
Oh trust me it is.. I fixed the wife's roadster 3 times.. and they went after my roadsters.. I purchased a stainless steel braid for tubing.. So unless they find some steroids somewhere they are done snacking on it..
Old Nov 6, 2015 | 01:57 AM
Red Runner's Avatar
Vacuum LIne from Engine to Heater Controls/Heater Fan
Pictures show where this line is located in the engine compartment.
Overview of engine compartment with line under the battery going toward the throttle body.
.....Arrow on the left is between the firewall & the heat shield.
.....Remove the screw in the heat shield at the right arrow to get better access to the line if there is a break in that area.
Line under battery holder.
Area between the firewall & heat shield where I repaired the line with rubber hose.
Line going into the manifold on the drivers side next to the throttle body.
Old Nov 6, 2015 | 06:21 AM
Ed Mahoney's Avatar
Wow awesome pic & write up ! Just another great place to get info on our cross fires !! Great job thanks !
CL770
39
May 7, 2026 09:15 PM
LHSIII
Aug 27, 2019 12:53 PM
Fla_Xfire_SRT
Oct 23, 2017 04:16 AM
Mark SRT6
Dec 17, 2015 04:24 PM
RED DOG
-C-I-C-C-I Discussion
Oct 14, 2015 02:57 PM
