Crossfire help
Old Apr 2, 2016 | 03:57 PM
Reevz1977's Avatar
Default Crossfire help
My increasingly unreliable Crossfire has now presented a new problem - the car will not start and just makes ticking noises. The dashboard lights are all on. I've tried jumping it and nada - any ideas folks? I'm a total car novice, so please use language a five year old could understand.
Many thanks
Old Apr 2, 2016 | 04:17 PM
Steve Jr's Avatar
Default Re: Crossfire help
Crankshaft positioning sensor. Back of the engine, from drivers side looking down. Use a Bosch, for the replacement.
Old Apr 2, 2016 | 04:23 PM
Mrmiata's Avatar
Not crank positioning sensor if the starter is not engaging.. No starter = RCM.. or battery possibly.. see the red link in my signature..
Old Apr 2, 2016 | 04:54 PM
Reevz1977's Avatar
Thanks so much folks - how do I know if it's the battery, is there any easy test?
Old Apr 2, 2016 | 04:58 PM
Mrmiata's Avatar
Volt meter Pretty sure anything below a 12v reading is not going to engage starter .. jump start.. Pull battery and have tested at parts store... digital readout battery charger..
Old Apr 2, 2016 | 05:02 PM
Yes, static with everything off measure across battery terminals, should be minimum 11.6 volts ( give or take ).
When running, 13.8 to 14.3 volts. ( yes, I know it won't start, but thought I'd tell you anyway )
I agree with mrmiata, probably the RCM.
Old Apr 2, 2016 | 05:27 PM
Steve Jr's Avatar
After rereading, I have to agree with the others(RCM). I assumed (an I know better), that your engine was turning over,and not starting.
(ASSofUanME)well just me.
Old Apr 2, 2016 | 09:09 PM
This car does not jump start unless the batt in the car is 9 cranking volts the best thing to do is replace the batt with at least a 850 cold cranking amp batt, to prove it turn on your headlights ,,,hit the starter,, lights go out you need a batt. lights stay on,,you need starter or sensor. j9im
Old Apr 2, 2016 | 09:58 PM
Dont forget the ground connection to the engine. Try to jump start with the neg jumper cable to the engine instead of the battery.
keith555
Jul 10, 2016 10:10 PM
leemeg99
Jan 21, 2016 02:08 AM
WindRestrictor
Jan 18, 2016 01:10 PM
summerstar
Jan 17, 2016 09:02 AM
summerstar
Jan 15, 2016 10:11 PM
