shifter knob and boot
Old Dec 14, 2016 | 05:06 PM
xfwilmingtonde's Avatar
Default shifter **** and boot
hi guys I've searched and viewed some posts but dont have a complete picture. wife wants a leather shift **** to replace cold metal one she has now in her base manual 2006 XF.
4 questions.
1. Will an SLK leather **** work? (before I spend $100 for it) ?
2. does the shift boot simply pull up and out?
3. I've read it's either threaded of there's collar to remove - think I'm good there once I can access under to boot.
4. Any helpful tips?
thank you all
Old Dec 14, 2016 | 05:18 PM
Default Re: shifter **** and boot
4 questions.
thank you all
The **** has a nut on the back side of it hidden under the boot, it is just unscrewed and you pull the **** of the shift lever.
You gently pry the boot of by getting under its frame as shown in the photo.
Old Dec 15, 2016 | 11:47 AM
thanks! very helpful
anyone now if the slk shifters will work on a manual XF ?
Old Dec 15, 2016 | 02:12 PM
harbor's Avatar
According to this German ebay seller, the shift ***** are interchangeable, but I wouldn't consider it as gospel.
ICT MERCEDES SLK R170 Crossfire shift gear **** gaiter illuminated leather LED | eBay
Old Dec 15, 2016 | 04:32 PM
The tranny is the same I believe so odds are it will fit.
Old Feb 23, 2017 | 02:09 PM
LGV-XFIRE's Avatar
All of the SLK shifters will fit Crossfires. Mine is a Manual and I have the SLK 6-speed shifter.
Old Aug 2, 2017 | 11:57 PM
Linc21's Avatar
How do you replace the boot? Does the boot come off of the retainer? Lol
Old Aug 3, 2017 | 12:33 AM
Linc21's Avatar
Really just concerned about the retainer bezel lol does the boot come off of it so I can just use the same bezel with my new boot? Thanks all!!
Old Aug 3, 2017 | 12:58 AM
Linc21's Avatar
When replacing the boot, does the bezel come off the boot? Or even better question since mine isn't bad. Can I keep the original boot still attached to the bezel, and change the shift ****?? Thank you for your time man!
[/QUOTE]
Old Aug 3, 2017 | 11:32 PM
Linc21's Avatar
Finally got mine off lol sprayed just a little bit of chain lube inside of it, and it came up much much easier!! Hahah thanks all!
Old Aug 4, 2017 | 08:46 AM
LGV-XFIRE's Avatar
Unless you're planning to change out the boot, don't take it off of the bezel. This will save come headache afterward. The rest of the headache now comes when you will need all five sets of hands to keep the boot in place while you screw the collar for the new **** on. (You have five sets of hands, don't you?)
