Clutch pilot bearing
Old Oct 7, 2018 | 03:48 PM
Salty1974's Avatar
Default Clutch pilot bearing
I would appreciate some advice. I have a 2005 xfire and i suspect a bearing is going on my clutch as there is a squeak when in low revs. Is it possible to replace the bearings as they have stopped manufacturing the clutch in uk. Or is it a full clutch and flywheel replacement. Keen to find a solution as don't want to have to sell her.
Old Oct 9, 2018 | 11:31 AM
Speedy4x4's Avatar
Default Re: Clutch pilot bearing
how many miles on it?
does it squeeze when driving at low revs or when engaging the clutch?
it is possible, but not done, since if the throw out bearing is shot, then while the engine and trans is seperate to go ahead and change it all, since if the bearing is gone, the clutch is not far behind.
besides the squeeze does everything seem fine ?
how long have you had it?
if had awhile does the clutch feel and shift into gear same as always ?
I looked on ebay and seen clutches from the UK
driving habits make a major difference on life of a clutch, even on Crossfires I have seen members have to change theirs at 50k miles and 240k.
I have 171k on mine atm.
Old Oct 9, 2018 | 05:11 PM
Salty1974's Avatar
Thanks for your reply and positive news that parts could be available in the uk. My car is 13 years old and I have owned it for 5 years. I bought it with 25,000 miles on the clock and it now has 42,000 on. The squeeze is not when changing gear but is there when in gear at very low revs. The shift from first to second has always been hard when cold but fine when warned up. The gears shift as normal no change no slipping. From researching the clutch kit i need the i think it's an luk 11-040 which is no longer available. Are there any alternatives? If so it would be really useful to know the make and model. Really appreciate any help you can give.☺
Old Oct 9, 2018 | 06:03 PM
Try Summit Racing in the US, they ship to Great Britian, estimated total cost is $591.72 US.
https://www.summitracing.com/parts/l...iABEgLvj_D_BwE
Old Oct 9, 2018 | 07:21 PM
How come we have gone from a little squeek to a complete clutch replacement? What connects the squeel to the clutch in the first place? Does it squeek with the pedal depressed or not depressed?
The thrust bearing could be wrecked but that is just one small item, without depressing the clutch there should be no squeeks from it. The pilot bearing has not failed once according to posts that I recall on here.
Old Oct 10, 2018 | 02:14 AM
Salty1974's Avatar
I realise this is quite a leap. The noise is coming from the gear box area and not the pulleys on the front of the engine and it definitely sounds like a bearing noise. The squeek is present when moving in gear. Depressing the clutch fields not make worse or better. It's when at really low revs ii.e. Need to change from 4th to 3rd, 3rd to 2nd.
Old Oct 10, 2018 | 11:17 AM
Speedy4x4's Avatar
just trying to get a good understanding of what kind of squeek and when and where at.
really annoying when I swear I know a noise is coming from rear passenger side, but turned out I found the problem on the drivers side.
with under 50k miles, I wouldn't think of the clutch or the throw out bearing, unless you tend to reat your foot on the clutch pedal, which will wear out the bearing. Alot of stop and go traffic and traffic jams is usually harder on the clutch, and your knee.
most of the time when I am just taking it out of gear, I don't use the clutch, just when lower rpm and the drivetrain is not in stress it slides right out, and to a stop when about at 2 - 3 mph before stop 1st gears slides right in with the clutch depressed and completly goes in 1st easy so no pop out when cold.
just different driving habits from several different transmissions, like a eaton 10 speed, when shifting you do "not" use the clutch at all.
trying to help, just trying to figure out what kind of squeak and when etc etc etc.
Old Oct 29, 2018 | 10:32 AM
liljay's Avatar
I actually had the throwout bearing (Slave Cylinder) replaced twice. If it's the slave it will drop to the floor or once it's completely gone, it will stay up and not allow you to depress it. I would drive it until it fails. It's not a big deal on the slave cylinder. You can purchase one for $42.00 on rockauto.com. I know it's no big deal, because I have a 2005 base with 208,000 miles. You will be fine. If you have to replace the clutch go with the luk not ams or buy a used off ebay. If you don't do the work yourself, you will never know what they put in. Speaking from experience.
Old Oct 29, 2018 | 12:44 PM
Didn't you mean to say 408,000 miles ?
Old Oct 29, 2018 | 01:23 PM
Good catch he mentions 337,000 miles in November 2015. CLICK
Old Oct 30, 2018 | 07:11 AM
I KNOW he has 400,000+ miles, he brought it over a couple of months back to install the OEM catback I sold him.
For that many miles, it is in remarkable condition !
Old Oct 30, 2018 | 12:18 PM
liljay's Avatar
Thanks Ala_xfire for the catch and the cat back. I really appreciate you. You are correct it's 408,000.
Salty1974
Oct 30, 2018 07:19 PM
robbie
Jun 29, 2015 05:57 AM
georges99
Jul 25, 2014 06:00 PM
S1CK TypeS
Jan 12, 2014 04:59 AM
Playdrv4me
Jul 18, 2010 04:28 PM
