Salty1974
I would appreciate some advice. I have a 2005 xfire and i suspect a bearing is going on my clutch as there is a squeak when in low revs. Is it possible to replace the bearings as they have stopped manufacturing the clutch in uk. Or is it a full clutch and flywheel replacement. Keen to find a solution as don't want to have to sell her.
how many miles on it?
does it squeeze when driving at low revs or when engaging the clutch?
it is possible, but not done, since if the throw out bearing is shot, then while the engine and trans is seperate to go ahead and change it all, since if the bearing is gone, the clutch is not far behind.
besides the squeeze does everything seem fine ?
how long have you had it?
if had awhile does the clutch feel and shift into gear same as always ?
I looked on ebay and seen clutches from the UK
driving habits make a major difference on life of a clutch, even on Crossfires I have seen members have to change theirs at 50k miles and 240k.
I have 171k on mine atm.
