V8, keep up with my mods
Old Dec 29, 2018 | 02:42 PM
Default V8, keep up with my mods
modding my V8 crossfire, and making test at the track after each mod,,, so far it is V8 engine and Rudy's built transmission . As most know i ran 11.78 in stock form ,,V8 with stock intake with K&N filters,,
pic here for now
https://www.crossfireforum.org/forum...-2016-228-.jpg
1. next will be 2.5 down pipes from engine, no cats to 3" exhaust will have a 3" flow through thrush muffler in the middle( to reduce the noise),, to my SRT 6 muffler.
2. and maybe Needswings super-cooler before next run.
Old Dec 29, 2018 | 06:50 PM
velociabstract's Avatar
Default Re: V8 ,keep up with my mods
Looking forward to results and updates.
Les
Old Mar 2, 2019 | 11:00 AM
rims will be replaced with black 17's or srt6 18 & 19"s
engine out
new seals gaskets and 1/2 painted
i removed the engine and tranny to do some mods,,paint,gaskets and seals and exhaust
Old Mar 6, 2019 | 09:02 PM
Speedy4x4's Avatar
Default Re: V8, keep up with my mods
Looking good
Old Mar 9, 2019 | 08:42 PM
cut!!!! removed the upper radiator support,,, lowered and moved forward the lower radiator support
Old Mar 14, 2019 | 02:25 PM
in the last few days we dropped the engine in 4 times did some modifying to lower the engine and tie it down,. the front is almost ready to install
wow side ways hood mount!!! LOL
Old Mar 14, 2019 | 08:18 PM
Jim .... what are you doing? Are you not a 1/4 miler? But dang it man, I approve!
Les
Old Mar 14, 2019 | 10:53 PM
Les
Hay Les, just fixing the car ,,lowering and moving forward the lower radiator support, for extra cooling ,,,and making the upper support ,,so i can change pulleys and radiator faster , you know with the v8 the engine is more forward so need to fix that, re balance the car, add brakes ect.. when i get through the car will be a 10 second daily driver LOL How is your car doing,,, i know you had it rough after the storm. lets go to the track!!! jim
Old May 15, 2019 | 08:01 PM
Engine back in,,, front end done,, see the fuel regulator
two 2.5 into 3" muffler
3" into srt 6 muffler
Miami Matt's shop
what about the water tank?
Old May 16, 2019 | 07:16 AM
Southernscrew's Avatar
Is that a washer and dryer you have attached to the muffler? Just saying.
Thanks, Ken
Old May 16, 2019 | 09:19 AM
Yes it is, this way i never have to wash the car,, when i turn the key off the washer starts,,
Old May 25, 2019 | 10:48 AM
water tank for use with supercooler, and need more fuel you need a regulator .
Old May 26, 2019 | 06:52 AM
ardenian's Avatar
Can you tell me how you have got your electric fans wired in?
Old May 28, 2019 | 03:13 PM
I have a fan from a C something i think it was a 300 and trimmed down to make it fit and hooked up- stock so far it has not run full blast and it was 89 yesterday, 1 needle width past 1/2 way is as high as it goes, stock thermostat.
Old May 28, 2019 | 04:45 PM
JEFASOLD's Avatar
pic here for now
Finally, somebody with some sense. I have been saying the only way to a proper exhaust is delete back cats then into y to 3 in pipe straight into stock muffler. phenomenal sound and slight power increase.. i'll post pics of my exhaust , if I can find them. I used a 12 I long resonator inline.
Old May 28, 2019 | 05:01 PM
JEFASOLD's Avatar
One other mod I've done is to use a eurocharged HE, which is much wider, then opened up the lower grills by drilling and grinding out a couple more squares on each side, which lowered my temps a few degrees, definitely worth the work.
Old May 28, 2019 | 05:32 PM
my exhaust is 2.5 off engine to the Y then 3" to a 3"resonator/open muffler inline then 3" into the srt6 muffler (((opened the muffler to 3" inlet and two 2- 2 1/2 outlets))
lowered the radiator support 3" and moved froward 3" modded fan from a mercedes car, set up on stock temp setings, the fan has never gone full speed, we did cut down the fan to fit into the crossfire. Needswings supercooler and small water tank in place of air pump, located high as the engine, fuel pump from mercedes with a adjustable regulator set at 65 psi,with vac hose to maintain 65 psi through out boost range.
I have a sound bite of the exhaust as soon as i can get it to post, tried earlier with no luck.
Old May 29, 2019 | 03:57 AM
ardenian's Avatar
Thanks for the info on your fan, but I actually meant the 2 electric fans you have in front of your rad.
Old May 29, 2019 | 08:53 AM
that ks what i was telling you about i just forgot to say that the two fans were removed and i replaced them with one big with more cfm ,,from the mercedes C class and had to mod it so it would fit.
Old Jun 22, 2019 | 10:59 AM
Went to Orlando speedway last night could not get traction. best run was
12.00 @ 115 and 12.20 @ 117 lots of spinning 13.2 @ 115 the exhaust increase the low end torque so the car is faster but need radials,
