Valve Covers
By chance does anyone know of a kit part number and where to purchase for replacing the valve cover gaskets? If I recall, there are upper and lower covers and hold down bolts should be replaced also. Sitting here bored as hell and figured I'd get them changed as they have been seeping awhile.
Going to replace rear camber arm bars also since the rear tires are wearing on the inside.
Thanks in advance for your help.
Fred
Fred
The real issue is to get the small valve cover on top to be sealed with a good amount ,and I mean thick,wait till it sets up, and that will do the job. Don't overtorque the screws,bad things will happen. Use Gasket cynch on the main seals,follow instructions.You may only be leaking from the top.
marksill
Aug 22, 2016 11:25 PM
God_Likes_Tebow
Feb 11, 2013 12:56 AM
04Fire
Nov 11, 2011 01:57 PM
Mr. F
May 16, 2008 05:13 AM
