Front alignment bolts
Old Dec 30, 2020 | 03:22 PM
Default Front alignment bolts
https://www.ebay.com/itm/Front-Cambe.../323531776567?
Old Dec 30, 2020 | 04:09 PM
Default Re: Front alignment bolts
For $20 more, Rob sells the kit of all four.
Old Dec 30, 2020 | 10:46 PM
all four is a better buy ,, if u only need two (one on each side = 2degrees each way, all four = 2 or 4 degrees each side foward or back, ) you could always buy the kit from rob (Needswings) and sell 2 of the bolts to make them $20 to $25 a set.
Old Dec 31, 2020 | 09:16 AM
Aren't two of the bolts for caster and two for camber?
Old Dec 31, 2020 | 09:27 AM
KDW4Him's Avatar
Yea, seems like one each side would adjust castor. Two each side will do camber.
Old Dec 31, 2020 | 10:00 AM
i don't know . the front suspension i am not good at, but my alingment guy tells me ,,,for the crossfire i need the lower control adguestment bolts one each side, (this is for my crossfire , the gray car and the black car , both V8) maybe not the v6 due to the weight,.
Old Dec 31, 2020 | 10:18 AM
zip439's Avatar
The forward bolt on the A frame is primarily camber. The aft bolt is primarily caster. However, you should think of the alignment as a three leg stool. Look at the suspension; It has basically three points of attachment. If you change any one of the legs on that stool the other two angles also change to a smaller degree. Changing caster or camber also changes toe which then should be adjusted back to spec.
Dfisher8400
May 12, 2019 11:27 AM
HDPursuit
Apr 28, 2017 06:15 PM
nautiquess
Feb 18, 2014 07:34 AM
RAM82A1
May 15, 2013 11:23 AM
04Fire
Jul 20, 2007 04:08 PM
