caliper covers
Old Jan 9, 2021 | 06:18 PM
dcskmail's Avatar
Default caliper covers
Just got my MGP Brake Caliper Covers but haven't installed them yet . I'll put them on next warm day here in the Illinois and post some pictures Dang me ! , I shouldn't have spent my wife's ss check !
My car is a sapphire silver blue , they should go good with the color
Old Jan 9, 2021 | 06:29 PM
Tom3120's Avatar
Default Re: caliper covers
Oh I like these. Hmmmm might have to look into this.
Old Jan 9, 2021 | 08:57 PM
dcskmail's Avatar
I had curved text CrossFire and custom paint very pricey but used the wife's money but I will tell her, if I'm on my death bed.
https://www.calipercovers.com/
Old Jan 10, 2021 | 06:55 PM
At that price you would really have to love them, that money would be better spent on a new battery and some oil.
Old Jan 10, 2021 | 09:59 PM
I've got a set of yellow Crossfire covers on my coupe. Bought the standard design to avoid added mark-up for custom work. These blue versions are "specials" with custom paint & lettering. Definitely a unique set!
Look on eBay for these caliper covers. Can usually find standard XFire versions at a reduced price. Make sure you look for covers for either the NA or SRT-6 models. Brake calipers are different!
Last edited by dedwards0323; Jan 10, 2021 at 10:04 PM. Reason: Added background info
Old Jan 10, 2021 | 10:45 PM
Tom3120's Avatar
I have a good battery and plenty of oil. What I don't have is caliper covers so not sure how buying more batteries and oil would be money
better spent?
Old Jan 10, 2021 | 11:40 PM
better spent?
My point is they are just bling, do nothing for the car and only fool the ignorant. For twice that money you could add SRT6 brakes. With the NA you can hardly see them anyway.
Your car, your taste.
Old Jan 11, 2021 | 09:16 AM
zip439's Avatar
Covers also retain heat; not what you want when you repetitively use your brakes. That is something to be mindful of. They do look great. I keep mine painted.
Old Jan 11, 2021 | 11:13 AM
dcskmail's Avatar
Thanks to all for your input. The way I drive brake heat is not an issue but MGP says they are designed to actually reduce heat here's a video :
and true they do nothing for the car but improve the looks but isn't it nice to fix up your car the way you want to and feel good about it.
Old Jan 11, 2021 | 02:56 PM
Thanks to all for your input. The way I drive brake heat is not an issue but MGP says they are designed to actually reduce heat here's a video : https://www.youtube.com/watch?v=ZABFN0Jl6QQ
I believe that ad is misleading. You have to take the temperature of the rotors and pads to see if they reduce heat (which I don't believe it will reduce, but may increase heat). All that ad does is show the outside temperature of the material they use to cover the calipers which I believe is just reflecting most of the heat inside those covers. Air is an insulator, if there is any airspace between the covers and the calipers, a lot of the heat will reflect back and/or flow around the covers. Check the temp's of the rotors and calipers, not exterior of a cover not originally part of the calipers. I believe you'll see an increase in temperatures on the covered side rotor and calipers..
dcskmail
Nov 25, 2020 09:35 AM
Moeron
May 28, 2019 02:13 PM
dedwards0323
May 30, 2018 06:22 AM
earlj
Jun 27, 2017 01:37 PM
xfireon20z
Dec 9, 2012 07:25 PM
