How do you change key fob so one click opens door and two clicks opens trunk and gas
Old Jan 22, 2021 | 11:30 PM
Mdcrossfire's Avatar
Default How do you change key fob so one click opens door and two clicks opens trunk and gas
​The above is how it use to be on my 2004 Crossfire but I must have held the button on the for down too long or something and now the gas cap door opens every time I open the door with one click.. I have to walk over to the gas lolcap door and hold it in while hitting the lock button. How do I change it back to the one click door two clicks trunk and gas door?
Old Jan 23, 2021 | 12:17 AM
philosophico's Avatar
Default Re: How do you change key fob so one click opens door and two clicks opens trunk and
https://www.crossfireforum.org/forum...oor-locks.html
Old Jan 23, 2021 | 08:06 AM
Your gas cap door should not open by itself when unlocking the car
It has its own latch to keep it closed regardless of whether car is locked or not
If it opens when you unlock the car then something is wrong with the gas cap door mechanism itself
Old Jan 23, 2021 | 09:50 AM
+1
The gas cap door is sprung shut from the mid point of its movement and sprung open after that.
There is a spring opening latch just like those on some cabinet doors that when pushed against they spring open, Valk and I believe this is the cause of your problems, it does not stay down in the closed position.
The proof of this would be that the gas door would be open all the time you are driving and locked only when you use the fob to lock the gas cap door down by holding itdiwn snd pressing the lock bottom on the fob. Opening the locked car from the outside will let the gas cap door pop open a little.
The gas cap door is only locked when you use the fob, it does not lock when you use the switch on the console.
croneca
Mar 11, 2016 11:41 PM
MiamiTVR
16
Jan 20, 2016 05:57 PM
cobraken
Feb 24, 2014 11:50 PM
green-ghost
15
May 7, 2011 03:02 PM
downwardspiral
Aug 7, 2008 04:10 AM
