Turn Signal Quirk
Old Mar 26, 2021 | 04:00 PM
CyberCG's Avatar
Default Turn Signal Quirk
I think I found a quirk in my 2004 XF. I noticed a pattern that might be caused by disconnecting the battery while I work on the XF.
Upon reconnecting the battery, I have noticed that the turn signals no longer work. If I push the Emergency flasher button, all four corners flash as they should. Then, after turning off the Emergency flasher, the turn signals work again as they should.
This has proven true several times.
I don't know why yet. Software/firmware feature maybe. But it works.
I thought that I would pass this info along to the group.
Old Mar 29, 2021 | 08:40 PM
CyberCG's Avatar
Default Re: Turn Signal Quirk
Nevermind! This isn't true. My turn signals are out again. Hazards work, but no turn signals.
Old Mar 31, 2021 | 11:41 AM
There is a turn signal gizmo in the under hood fuse panel if I remember correctly. It may have failed.
Old Mar 31, 2021 | 01:14 PM
JSK's Avatar
JSK
Dont be so damned technical. It goes over everybody’s head.
Old Mar 31, 2021 | 01:23 PM
It is actually a relay not a gizmo. 😀
Old Apr 16, 2021 | 09:50 PM
CyberCG's Avatar
My turn signal problem turned out to be self inflicted. I had totally removed all the dash and console plastic panels for painting. I discovered that during reassembly, the Emergency Flasher wiring connector did not properly click into place. This caused an intermittent connection that would cause the turn signals to not operate at times. I properly seated the connector and now the turn signals work as they should.
Old Apr 17, 2021 | 12:03 AM
Ronman's Avatar
Thank for letting us know and happy you solved the problem. What kind of paint did you use for the plastic panels? Were they worn out?
Old Apr 17, 2021 | 03:10 PM
CyberCG's Avatar
The interior plastic panels were showing scuff marks and were looking worn. I changed the light gray to dark slate and used SEM Color Coat. I also took the liberty to introduce some Firethorn Red, also a SEM color.
Romad
Feb 11, 2021 10:18 PM
Furgal
Oct 30, 2020 03:27 PM
D16
Mar 8, 2018 09:39 AM
D&D
Jun 27, 2007 09:34 PM
rakoom2002
Oct 29, 2006 12:10 AM
