AC is intermittent?
Old Jun 10, 2022 | 06:26 PM
No704's Avatar
Default AC is intermittent?
‘05 roadster. AC works intermittently? Added a little Freon this am. Compressor engages.
maybe sticky evap valve? Looking for similar experience? What is the charge capacity? Looking under hood could not find an ac sticker.
thanks all.
Old Jun 10, 2022 | 10:49 PM
No704's Avatar
Default Re: AC is intermittent?
thanks all.
Had it on yesterday and it did work for a minute. Could not locate a high side port. Looks like there is a t off the dryer, is this for a high side port? Any body know of a fitting?I’m in Arizona, so it’s 113 outside now.
Maybe the inside temp sensor?
if I fire the parts cannon is a slk350 the correct car to pick on fcp euro? Or I am open to other sources.
Old Jun 10, 2022 | 10:53 PM
No704's Avatar
I have tried the search function, maybe I’m doing it wrong, but don’t get any results searching “AC”
Old Jun 12, 2022 | 04:00 PM
No704's Avatar
Ordered this. Hope it will work.
Old Jun 13, 2022 | 08:59 PM
No704's Avatar
SLK fourm says if the Freon charge went low it has to be reset with a scanner. Haven’t seen anything to that effect here. Is it a thing?
Old Jun 14, 2022 | 01:41 PM
nemiro's Avatar
Do not believe any reset is required for the Crossfire/R170. R171+, probably yes, but that does not affect us.
Old Jun 14, 2022 | 05:39 PM
No704's Avatar
Thanks for that info, that will make things easier. I am leaning toward that I probably Need a new expansion valve. I’ll probably get a new dryer too. Any body have any experience with the scanner I posted before?
fcp euro doesn’t list parts for a slk320, only the SLK350. Is this what I want, or does anyone have correct part numbers?
Old Jun 14, 2022 | 06:04 PM
nemiro's Avatar
For the A/C system parts, go to Rockauto.com They'll have what you need, for a lot less.
Old Jun 14, 2022 | 06:28 PM
No704's Avatar
Good point, and they actually list a Crossfire!
Old Jun 14, 2022 | 06:29 PM
No704's Avatar
Anybody have the capacity specs on this system?
Old Jun 14, 2022 | 08:30 PM
No704's Avatar
Thanks, rock auto is way cheaper! Will get parts next week and update.
Old Jun 15, 2022 | 08:58 AM
I believe the freon capacity is listed in the forum's free downloadable service manual. Make sure you do a proper vacuum on the system to draw out ALL the moisture before injecting the freon. Best if you have a gauge set, so you don't overcharge (you can damage the system). IF not. do the replacement of the parts and bring it to an A/C guy to install the freon (the parts needed to properly install the freon is VERY EXPENSIVE) Good luck!
Old Jun 15, 2022 | 09:13 AM
nemiro's Avatar
BTW, the capacity of a Crossfire A/C system is 1.97#.
Old Jun 15, 2022 | 06:09 PM
No704's Avatar
Thanks guys, I have gauges and a vacuum pump. Should get parts on Monday, just have to find time to install them.
Old Jun 15, 2022 | 07:09 PM
Deepsea21's Avatar
Remember to run the engine, drive it around, whatever and get it up to full running temp under the hood. Then shut it down and hook up the vacuum pump. The hotter the engine and engine compartment is when you start evacuating the system the more moisture you'll pull out with the pump. The pump isn't just to evacuate the system of air as best it can but to also pull all moisture out of the system as well. Higher temp + vacuum = lower boiling point of water in the system under the vacuum the pump can create. You get far more moisture out of the system if you place it under vacuum when everything is hot.
utsilverfox
Jul 23, 2021 02:46 PM
DaleM
Sep 6, 2018 07:27 PM
Carolinacruizer
Jul 20, 2011 12:35 AM
xxfirerican
Jan 15, 2010 01:01 PM
Skyshadow
Apr 28, 2009 06:56 PM
