Windshield replacement for Crossfire Coupe
Old Aug 7, 2022 | 01:05 PM
Jockmo's Avatar
Default Windshield replacement for Crossfire Coupe
Does anyone know where I can obtain a new windshileld for a 2006 Crossfire Coupe? The bodyshop I am dealing with in Atlanta says they are having a hard time finding one.
Old Aug 7, 2022 | 04:41 PM
DTMenace's Avatar
Default Re: Windshield replacement for Crossfire Coupe
Jockmo
Click on the attached link and it will lead you to a forum member that is selling new windshields...
Good Luck,
Dennis
DTMenace
New windshields - CrossfireForum - The Chrysler Crossfire and SRT6 Resource
Old Aug 7, 2022 | 08:47 PM
Jockmo's Avatar
Thanks, I'll check it out.
John
Old Aug 9, 2022 | 09:25 AM
zip439's Avatar
I had the same problem recently when looking for a windshield for a 2005 Mercedes CLK 500; Bought one from a junkyard within driving distance. The windshield I purchased was in excellent condition and original to the car. $100 well spent.
Old Aug 9, 2022 | 10:07 AM
Jockmo's Avatar
I will suggest that to the body shop in the event they can't locate a new one. I'd prefer a new windshield since they were responsible for cracking it in the first place.
Old Aug 9, 2022 | 08:45 PM
rush549's Avatar
When you have that windshield replaced have them take special care when putting that trim back on or you'll soon be looking for that too. It's a notorious problem with these cars.
Old Aug 10, 2022 | 10:43 AM
zip439's Avatar
That is a very good suggestion! The clips that hold the windshield trim in place use two sided tape. If the shop who does the windshield replacement doesn't have any in stock get some of the best available from a body shop and bring it with you. The roof trim piece comes off first, then the sides.
Old Aug 10, 2022 | 01:00 PM
Jockmo's Avatar
Good to know, thanks.
Old Aug 10, 2022 | 01:18 PM
Many have used the WRONG double-sided tape, make sure the right stuff is used. When you lose one at speed, you'll regret not buying the right tape (as others have found out trying, yes trying, to replace them). The parts are HARD to find and EXPENSIVE! Good luck!
Old Aug 10, 2022 | 01:40 PM
Jockmo's Avatar
Do you know what brand is the correct type of double sided tape?
Old Aug 10, 2022 | 04:27 PM
zip439's Avatar
That is why i suggested a body shop and not an auto parts store. You may also try a supplier for auto paint, but I would go to a body shop and buy some from them, It only needs to be about 1 inch wide as you can put on several strips alongside each other. 3M makes good stuff, just get the right stuff.
Old Aug 11, 2022 | 09:41 AM
Jockmo's Avatar
Thanks for the info, I'll make sure it gets the right tape when the windshield gets installed.
Old Aug 11, 2022 | 02:37 PM
JSK's Avatar
JSK
I think the best course of action is to remove the trim yourself and reinstall it after the windshield has been replaced. You will probably be more particular then the installer.
Old Aug 11, 2022 | 04:05 PM
Jockmo's Avatar
Good idea. Thanks.
Old Sep 5, 2022 | 12:52 PM
Goldwing's Avatar
I went to Safelite in July 2019 for my roadster and it was $377 for aftermarket glass. OEM glass was over a hundred more but it had the "right" decals. I passed and the aftermarket it clear with no defects.
Old Sep 5, 2022 | 03:43 PM
Jockmo's Avatar
Thanks for the info.
Craftmatic
Mar 9, 2017 05:06 PM
hotwheels
Jan 12, 2014 04:33 AM
2005 Ragtop
Detail Shop
Jun 13, 2012 10:39 AM
SCasares
South Forum
Sep 13, 2010 01:13 PM
stlxfire
Jan 21, 2005 06:29 AM
