74mm throttle body
Old Aug 10, 2022 | 11:51 PM
dcskmail's Avatar
Default 74mm throttle body
Where is the place and brand to buy a 74mm throttle body for my 07 n/a ?
Old Aug 11, 2022 | 01:33 AM
Sussudio's Avatar
Default Re: 74mm throttle body
‘Search on eBay Mercedes 74mm throttle body. It’ll bring up used ones but should also have new ones by some of the companies that make them. They can get super pricey brand new just an FYI. VRP carries them iirc. Also Needswings I believe has them. I can’t remember if he said they were going to stop carrying them or not, I think it was just for the SRT6 that they were going to discontinue them. Chime back in on what you find
Old Aug 11, 2022 | 08:43 AM
bc75's Avatar
I bought a used one from Needswings they sell used or new. Been running the used one for almost 2 years no problems.
Old Aug 11, 2022 | 09:36 AM
dcskmail's Avatar
Thanks to all for the info, it's appreciated
Old Aug 26, 2022 | 10:16 AM
MPIN67's Avatar
I bought a used one on eBay for $43 and it works perfect!
Old Aug 26, 2022 | 01:23 PM
Many many years ago (in my signature, June 2012) I purchased one off Ebay, never had a problem. With 'used' ones you just need to make sure it not only looks good, but the 'ad' has Ebay's money back guarantee (as the term used denoted it works 100%). Only additional I have, follow the .pdf in the document collection & MAKE SURE the rubber gasket does not slip out of the groove during installation. I used a small amount of petroleum jelly to 'hold' it in place until mounted. If your careful, there will be no leaks from an improper seal of that gasket. There will be (in most cases) a relearning of the ECU when first started but that should go away within a few miles/starts/stops. If rough running still happens, you probably have a slight vacuum leak somewhere. Good luck!
BRYAGUY
Jan 30, 2016 01:41 AM
ardenian
Jul 9, 2015 02:08 PM
onehundred80
Aug 14, 2011 06:21 PM
Eric
Feb 16, 2011 10:23 PM
jediracer
Nov 4, 2009 06:05 AM
