wheel studs look like a good idea to me
Old Dec 19, 2022 | 07:47 AM
waldig's Avatar
Talking wheel studs look like a good idea to me
I found this and wonder if they are available to us. ROB are you looking at this !!!!!!!!
https://www.thedrive.com/guides-and-...de-life-easier
This is a good idea and makes the wheel installation easy. LONG AGO I posted the process of cutting the head off a long bolt to screw into the hub to align and ease the placement of the wheel when installing them. This PIN made the wheel alignment a bit easier while fumbling with the tire weight.
what say you all??? Woody
Old Dec 19, 2022 | 09:30 AM
Default Re: wheel studs look like a good idea to me
Great idea if the tapered nuts for our cars are also available. As we get older, it gets harder to hold up the wheel and align the holes.
Old Dec 19, 2022 | 10:57 AM
velociabstract's Avatar
I did this a decade ago as I was swapping rims constantly. Street, drag and track. Not to mention experimenting with spacers to vary the offset. (track racing purposes) The heat from racing made a thread locker a requirement. Having 3 sets of rims with different offsets, I needed long studs. They simplified my life for sure. However, the hub caps don't fit over the longer studs.
Les
Old Dec 23, 2022 | 09:38 AM
zip439's Avatar
I have found it relatively painless to replace and tighten wheel when using one of Woody's long thread headless bolts to get it started. The trick is to set on the ground with your legs under the car and the wheel on you upper legs above the knees. Using your large legs muscles to adjust the rims hole to line up with the long bolt and then sliding the wheel in to place is easy enough and NO BACK PAIN. It is a dirty job, but not hard when in a setting position.
Old Dec 23, 2022 | 01:37 PM
JSK's Avatar
JSK
I too was struggling with putting wheels on, went to the hardware store about 3 or 4 years ago and bought a long bolt, cut the head off and ground the edges round and haven’t had any struggles since. Money well spent.
Old Dec 23, 2022 | 08:51 PM
dcskmail's Avatar
Wheel hanger, look on youtube for wheel hanger video, available below for $9.50 pack of 2 , verify size, I believe M12x1.5
xx xx xx xx
https://www.amazon.com/Steel-Wheel-Hanger-Alignment-Guide/dp/B07SFZTSRG/ref=sxin_15_pa_sp_search_thematic_sspa?content-id=amzn1.sym.93bf312b-c5e0-435e-b7c1-6c5db8f43f0c%3Aamzn1.sym.93bf312b-c5e0-435e-b7c1-6c5db8f43f0c&crid=34LHURSMBA8TH&cv_ct_cx=wheel%2Bh anger&keywords=wheel%2Bhanger&pd_rd_i=B07SFZTSRG&p d_rd_r=12440969-1beb-4e49-ba8f-0bcdea061061&pd_rd_w=ad2Al&pd_rd_wg=h9ub4&pf_rd_p= 93bf312b-c5e0-435e-b7c1-6c5db8f43f0c&pf_rd_r=0HAWC6FCQ2NZ7BHVQ7TQ&qid=1671 846380&sprefix=wheel%2Bhanger%2Caps%2C255&sr=1-5-a43b4223-fbe9-48b0-af69-6d70cf84978b-spons&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFQSEJRVUpWSlB TUzMmZW5jcnlwdGVkSWQ9QTAxNjA2MjgyRkJLVjc4MzE1S0k5J mVuY3J5cHRlZEFkSWQ9QTA5MjUyNzcyQURVRDQ4N0s4NkI2Jnd pZGdldE5hbWU9c3Bfc2VhcmNoX3RoZW1hdGljJmFjdGlvbj1jb Glja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ&th=1
Old Dec 24, 2022 | 02:51 PM
IF the M12x1.25 is accurate, then get an idea from this link. I purchased my set of 2 off Ebay (my set of 2 are a lot longer than the one offered in this (
Amazon Amazon
) link). Searching M12x1.25 will get you a variety of sizes/prices. Make sure the size you settle on fits! Good luck!
Old Dec 24, 2022 | 03:23 PM
nemiro's Avatar
I went to studs on my car. Makes getting the wheels on and off much easier. I also have more thread engagement in the hub than the stock bolts had. I did grind the heads down just a bit to get as much threaded length as possible, but still be able to put the stock SRT6 hub caps on.
Old Dec 28, 2022 | 03:24 PM
KDW4Him's Avatar
I have no problem hanging the wheel on the center hub for a few seconds to align the lug and start a few threads deep.
Old Dec 28, 2022 | 04:13 PM
Nor I.
Old Jan 24, 2023 | 12:50 PM
Goldwing's Avatar
I use a bolt with the head cut off (two different sizes) for my Crossfires, Audi, and Maserati. Makes it much easier for an old(er) guy who removes, cleans, and waxes four sets of rims annually.
Old Jan 25, 2023 | 04:57 PM
Padgett's Avatar
I find hanging the tire on a stud make life easier.
Old Jan 25, 2023 | 05:14 PM
dcskmail's Avatar
Default Re: wheel hanger look like a good idea to me
Wheel Hanger Alignment Pin Guide Tool - Metric 12x1.5 - Mercedes Wheel Mounting Guide Bolt - Pack of 2, $10 amazon
Old Jan 25, 2023 | 05:50 PM
This is the best idea imho, fit the wheel to one stud and rotate the wheel until it lines up to the location diameter on the hub. Keep the minimum gap under the tire. Or use two bolts one an inch or so longer than the other and both with a nice gentle taper on the outside end.
Remember to clean the location diameters and add a spot of lithium grease to them to retard any corrosion. Clean the faces where the bolts go through.
Old Feb 14, 2023 | 04:01 PM
Duke11's Avatar
I had to pull all four wheels today to change/add spacers, this alignment pin worked great. No need to sit on my butt with my legs under the vehicle (always with wood blocks under the car for safety). Hard to go wrong for $10. Nice to have in the event of a flat tire.
Old Feb 14, 2023 | 06:18 PM
i used the hanger/alignment tool for 13 years now Mercedes p.n sorry don't have it.
as for the studs, they are not to be used for racing,(i know some of us do it anyway) the studs go all the way through as you know, if your rear studs are too long and go in too far they hit the emergency break cable. i do not use spacers or studs and yes it is a pain in the *** to install the wheels so i buy the almost drag radials tires for the street, they are std on 6 to 700 hp cars like bmw and mercedes that are very solff, and last about 40,000 miles.that way i don't have to change tires at the track any more.
look at https://www.crossfireforum.org/forum...-new-post.html you see i got a o.15 light and a 1.888 60' so yes they grip,, street tires and open rear. jim
Old Feb 15, 2023 | 08:43 AM
I've got a couple of wheel hanger pins for the Crossfire, along with a couple for the 2016 VW Beetle Dune we have. The Beetle uses the 14x1.5 thread. These have come in handy quite a bit these past few years.
Old Feb 15, 2023 | 09:08 AM
Padgett's Avatar
"Nice to have in the event of a flat tire.". Also a tire repair kit, universal tube, and a compressor.
Bjm65
Jan 24, 2023 02:01 PM
Clarkcou
Mar 18, 2018 05:22 PM
saltiga
Australia
Dec 18, 2014 12:45 AM
southtexas
Jan 24, 2009 06:05 PM
prowler39
Feb 9, 2004 10:15 PM
