Seatbelt replacement?
Old Apr 26, 2026 | 08:22 AM
mistykup's Avatar
Default Seatbelt replacement?
I tried searching for replacement instructions for the seatbelts, but didn't come up with much. Has anyone replaced them that can guide me? Both sides have been eaten about 20%across from mice.
Thanks Friends!
Old Apr 26, 2026 | 03:17 PM
copperfieldkid's Avatar
Default Re: Seatbelt replacement?
Seatbelt replacement costs range from $20 to $85 per part, with labor adding roughly $100–$125 per seat. Specialized services like SafetyRestore or MyAirbags offer repairs or OEM replacements, often with 24-hour turnaround. Professional installation is recommended to ensure safety compliance
Old Apr 26, 2026 | 03:21 PM
Nelson G's Avatar
Thanks Friends!
I have a set of seat belts that you can have for the cost of shipping. I had a company redo my seat belts in a color. What I did was purchase a used seat, and they used those, and when I received the new ones, I changed them. I will say when they came, they were in a position where you had to be very careful, as they needed to put in a particular order. I have a PDF I found that shows me how to get them out and how to put them in.
I could email it to you. You will have to disconnect the battery, which is why I went with purchasing an extra set to make it easy. You will need to remove the trim at the back where the belt exits. At the bottom of the belt is bolted, and that is where the electrical connection for the seat belt is.
You can email me, and I will send you the PDF I have. gonzalez@earthlink.net
Nelson
File Type: pdf
Last edited by Nelson G; Apr 27, 2026 at 02:44 PM. Reason: needed to add something
Old Apr 27, 2026 | 02:28 AM
Mistykup, like member Nelson said, disconnect the battery before starting the work (never seen the .pdf, don't know what is in it). The seatbelt system is also monitored by the SRS system (2008 Manual, Vol #2, Pg. 80-560 to 80-572 (other year manuals may have different page numbers). Good luck!
Old Apr 27, 2026 | 03:11 PM
mistykup's Avatar
Thanks friends! I already purchased the replacements from ebay, so i just needed the instructions/ moral support! Thanks for the pdf!
simba4536
Jul 8, 2024 08:20 AM
rednrollin
Feb 4, 2022 12:34 AM
crookedview
Apr 6, 2017 04:05 PM
X-MAN
Jun 28, 2010 10:08 AM
REDCROSS
Dec 30, 2004 12:56 PM
