Head Unit pull-out tool
Old Jan 7, 2007 | 04:54 PM
Default Head Unit pull-out tool
Anyone out there that has replaced their OEM radio head unit, who's interested in selling the tool to pull out the radio? Please PM me, and let me know.
Thanks.
Old Jan 8, 2007 | 12:00 PM
raulito11
Guest
Posts: n/a
Default Re: Head Unit pull-out tool
I don't have the tool but here is a link of where you can one: http://www.crutchfield.com/S-g8ezRmh...20&I=120869001
Old Jan 8, 2007 | 12:05 PM
Thanks raulito, I have a member sending me his.
Old Jan 8, 2007 | 12:23 PM
raulito11
Guest
Posts: n/a
No problem FP...what kind of aftermarket head unit are you getting, I should be getting mine soon...waiting for it to be shipped to me. I take it you are doing it yourself, let know how it went...I want to install mine but never done it before...it seems that circuit city and best buy don't know what they are talking about when it comes to a xfire.
Old Jan 8, 2007 | 12:47 PM
I'm not replacing my head unit, but need to pull it out to install the Phatbox.
Old Jan 8, 2007 | 03:02 PM
You might want to try Tweeter. They have personnel that work with more sophisticated solutions.
Old Jan 8, 2007 | 10:07 PM
marauderroy's Avatar
If you bought from Crutchfield they will send you everything you need. It's a piece of cake to install, Do it yourself and save the money.
No need to run new wires, Just wire up a plug and use the stock amp. It will sound better with an aftermarket radio. See this thread for info. See post #9 on this one.
https://www.crossfireforum.org/forum/...ead.php?t=9057
And this one too.
https://www.crossfireforum.org/forum/...ead.php?t=9308
And check out the Audio section of the forum, There is a lot of info there.
Old Jan 8, 2007 | 11:37 PM
I put the tool in the mail this afternoon. Let me know when it gets there so I know it made it.
Old Jan 9, 2007 | 05:40 PM
MMZ_TimeLord's Avatar
Funny, I took the pictures of the tools on the net and made a set for nearly $0.00. Just some time with a hack saw and needle file set I already had on some mild sheet steel.
Old Jan 13, 2007 | 03:36 PM
Thanks Roy, it came in today.
Hopefully I have time this weekend to work on this project.
Old Jan 13, 2007 | 07:15 PM
Sent a reply to your pm before I saw this post. Glad you got it. Now...Get to work.
Old Jan 13, 2007 | 07:30 PM
I think I figured out you have to push the key (tool) all the way in each slot, and the unit pulls out really easy, but will the tool pull out relatively easy after I push the head unit back in?
Old Jan 13, 2007 | 08:14 PM
Remove the tools after you get the unit out of the dash. You don't need them to install it, just slide the unit in until it "clicks" into place.
Old Mar 2, 2007 | 06:47 PM
Bostonsrt6's Avatar
Heyyy anyone have the tool for me? I will send along to the next person once I am done. Btw I am installing an avicn-1. I have a harness for an evo already do I need a different one for the srt6? Any suggestions guys?
Thanks!!!
Old Mar 3, 2007 | 02:40 AM
Hi Boston. I think you are going to need a new harness for the crossfire. Good luck with your install.
Old Mar 3, 2007 | 04:43 AM
Here is a PDF that you can print and it should give you a template to scale. All you need from there is a small bit of stiff sheet metal and some time with a hack saw and needle files.
Hope that helps.
Old Mar 3, 2007 | 10:14 AM
Bostonsrt6's Avatar
Thanks guys! Anyone know which harness works with the crossfire? If I go to bestbuy will they have it?
syfi
Mar 28, 2026 04:14 PM
Sterling57
Apr 11, 2016 06:11 PM
smokey847
Nov 12, 2015 11:54 PM
crossfireE
Oct 2, 2015 01:40 AM
smokey847
Sep 15, 2015 10:47 AM
