AMG airbox installation
Old Apr 15, 2007 | 07:37 PM
Cincinnati Slim's Avatar
Thumbs up AMG airbox installation
Hello Folks,
Picked-up a AMG airbox assembly for a 3.2 from member Advanz.
Got it installed and pictures are posted in my member's gallery.
I used the air intake tubes from a 2005 STR6 Crossfire. I think they may use the same airbox. Right now it's held together with industrial strength zip-ties which will soon be replaced by aircraft grade stainless band clamps.
I think this should settle the argument about the BEST available cold air intake. This set-up uses TOTALLY factory parts, inhales cold air, has HUGE filter panels and flows enough air for a 350+ horsepower motor.
I'll post all the Mopar/AMG/Benz part numbers tomorrow.
Cheers,
Cincinnati Slim
p.s. Thanks Advanz !
Old Apr 15, 2007 | 09:47 PM
XFireHammer's Avatar
Default Re: AMG airbox installation
Originally Posted by Cincinnati Slim
Hello Folks,
Cheers,
Cincinnati Slim
Let's see some pictures, I'm always interested in something "Cool" ...
Old Apr 15, 2007 | 10:26 PM
andrew's Avatar
-C-I-C-C-I Associate Member
~ here is the link to his gallery with additional pics:
https://www.crossfireforum.org/galle...0&ppuser=13773
Old Apr 15, 2007 | 11:21 PM
Thirteendog's Avatar
That's actually the same intake used on the SRT6's. Not to mention the SRT6/Limited/Base model crossfire share the same air-filters.
Old Apr 16, 2007 | 03:19 PM
MAYAman's Avatar
Argh I'm so mad at you I was going to buy that and you beat me to it!!! Now all you need is the SRT engine cover and you're straight!
Old Apr 16, 2007 | 04:59 PM
Maxwell's Avatar
this square thing is the MAF right, but how is it connected to the "Y" pipe? did you have to modify something to fit properly?
Old Apr 16, 2007 | 05:00 PM
Sorry MAYAman...
I'll post the part numbers here soon so you can achieve the same results.
As for the engine cover, I'm not going that route.
One of the main objectives was to be able to SEE the motor when the hood is opened !
Thanks,
Slim
Old Apr 16, 2007 | 07:46 PM
Maxwell,
The "square thing" is just the top pf the "y" pipe assembly.
There's a sort of dished "lid" attached by a set of torx screws.
No mods were needed except I had to remove the rubber seal inside the "y" pipe where it attached to the MAF. The Crossfire MAF is about 1/8" too big for the Benz "y" pipe. I'm using a fat elastic band a a seal now. It is actually a drive belt for a sweeper; origin unknown. Just a big tough rubber band really. Nice snug and no leaks. I'll replace the industrial strength zip-ties with stainless band clamps in the next few weeks for a more "factory" look.
Old Apr 16, 2007 | 11:24 PM
advanz's Avatar
it looks sexy as hell! i'm glad you like it!
Old Apr 17, 2007 | 12:18 AM
Romio's Avatar
You had to mod your engine cover didn't you? Because you would still have to 2 black tubes to connect the intakes into, but now your bypassing it. Any pics with cover on?
Old Apr 17, 2007 | 07:06 AM
bobs's Avatar
Looks good, but now you have to do something with the intake manifold. I would look mighty good if it were polished.
One question for you: How's the performance? Any better or worse?
Old Apr 17, 2007 | 08:40 AM
andrew's Avatar
~ its my impression the cover will now not fit... b/c of the increased size of the rear tubing. that's the downside.
Old Apr 17, 2007 | 10:10 AM
Honestly, one of the main goals was to get rid of the engine cover !
I like being able to see the motor. I have the base model coupe so the cover is plain black plastic. Blah !
I like seeing the intake alloy casting. Yes, it would look good polished but that's not really in the budget. I am considering a silver-grey "hammertone" paint job via a Rustoleum "rattle-can" for the raw alloy manifold.
Sorry to say, I never did any base-line total stock runs so I'm not going to make performance claims. I'll put my stock intake/cover on when I go in for my first oil change. ( which is free at Wullenweber, the dealer I purchased it from ). The Edgewater dragstrip is only about three miles from there. If It's "tune and test Friday" I might do some runs with the stock intake/cover in place. I'm going to get a "top-sider" and do my own oil changes after that.
I like Wullenweber's service department but given the stories I've heard about service on these cars I plan on staying away unless something major breaks while under warranty.
Slim
Old Apr 17, 2007 | 10:39 AM
Romio's Avatar
maybe you could fit a SRT or AMG or Benz cover.
Old Apr 17, 2007 | 11:35 AM
Default Part numbers from AMG airbox installation
Greetings,
Here are the part numbers for this set-up...
Air intake tubes from radiator area to air boxes, Benz and Chrysler parts numbers as follows...
A 112 094 15 82
05135452AA
and
A 112 094 14 82
05135451AA
The rest are M-B/AMG numbers on the parts...
MAF "Y" pipe...A 112 090 01 29
Rt. Flex Tube...02 6367 A
Lf. Flex Tube...02 6367 B
Rt. Airbox...A 112 090 1001
Lf. Airbox...A 112 090 0901
These are probably also listed under Chrysler part numbers for SRT6 applications. A helpful parts guy or a wrecked SRT6 could confirm this !
I DO like being able to SEE the motor now!
Cheers,
Slim
Old Apr 18, 2007 | 01:10 AM
advanz's Avatar
it looks hott like I said!!! and brent, you SHOULDN'T get a amg front cover, leave it as it is! or infact, when you have TIME. get engine paint, paint the air boxes red. (or silver) and polish the top of your engine!
and no joke about additional upgrades on my 320coupe. lol for example. here is a recent one. aka today.
glad I helped you out brent!
Old Apr 18, 2007 | 12:10 PM
Thumbs up Re: AMG airbox installation
Ohhh Yea, Carbon fiber !
Looks like some of the parts I saw while working for GE aircraft engines at Peebles and Evendale. Very high-tech, aerospace grade sort of stuff there...
Slim
Old Apr 18, 2007 | 05:49 PM
advanz's Avatar
Slim
yeap, its a carbon fiber airbox from RENNTECH!!! wow, the sound and power with this is amazing...AMAZING!
Jonacross
20
Jul 17, 2017 11:19 PM
zackman62
Nov 6, 2015 12:37 PM
Sep 13, 2015 02:12 AM
crmnal
Sep 6, 2015 08:07 AM
PA/XFIRE
Sep 5, 2015 01:25 PM
