Turbo Charger Question
Old May 25, 2007 | 02:58 PM
jchamberlain's Avatar
Default Turbo Charger Question
First and foremost let me make it explicitly clear that I know very little about cars (otherwise I wouldn't be asking for help). I know just enough to take good care to maintain my vehicle. That being said I have a question regarding turbochargers/superchargers. I own and 04' coupe ltd. I am looking to enhance the performance a bit and increase the retail value a little. I found a couple of turbo chargers that I think would work for my engine. I was considering purchasing it, but wanted to do some research first. My first question is, is this part in fact even compatible with my engine and could it even be installed? Second, as I mentioned previously I know very little about cars so in the event that I did acquire this part would there be any additional accompanying parts to have it installed? I am aware of how a turbocharger works and can only assume that I could not simply slap a turbo charger onto the engine and be able to drive around, and that perhaps I would need to acquire something additional to maintain proper function of the car. Next increasing the output would surely put more stress on the engine and its vital parts so would adding the turbocharger degrade the life of my engine? If so (going along with the previous question) is there something I could do or a part I could acquire that would prevent any degradation in the life of my engine? Lastly would the increase in performance really be of any benefit or would I just be wasting my time?
Any help and suggestion would be greatly appreciated.
Links to the parts in question:
http://www.amazon.com/Chrysler-Cross...115924&sr=8-14
http://www.amazon.com/Chrysler-Cross...116000&sr=8-39
Thank you for your time,
Justin
Old May 25, 2007 | 03:18 PM
The Madhatter's Avatar
Default Re: Turbo Charger Question
there is much more to this project than you anticipate, you must build custom headers/downpipes, custom exhaust, possibly an intercooler setup and an intake. if you are not very mechanically inclined do not even attempt this. call a shop and see if they can build you a custom setup because there isn't a bolt on setup for these cars. the price you were lookin at was just for a turbo.
Old May 25, 2007 | 03:24 PM
baksdak's Avatar
Not trying to be rude, but if you have to ask any of those questions then I would suggest you not even think about doing this.
Old May 25, 2007 | 03:39 PM
RPM's Avatar
RPM
Moderator
Many have come through here speaking of turbos, etc. One current member is attempting this on his Crossfire (drift car). He seems to have come the closest of anyone. Do a search on the forum for 'drift' or 'slide project.' It will tell you the route he is attempting.
Old May 25, 2007 | 03:53 PM
Thanks. That is exactly the sort of thing I needed to have answered. Now I know where to begin.
Thanks.
Old May 25, 2007 | 03:54 PM
Foremost I had no intention of doing the work myself, so if it's done properly I see no difference in whether or not I posses the knowledge of doing the work. I just wanted to know where to begin. I do appreciate the concern though.
Old May 25, 2007 | 03:55 PM
Thank you for you're input I know where I should begin now.
Old May 25, 2007 | 05:39 PM
Maxwell's Avatar
you must have a lot of money burning holes in your pockets ay?
Old May 25, 2007 | 06:15 PM
intenseblu's Avatar
Originally Posted by Maxwell
you must have alot of money burning holes in your pockets ay?
how constructive ... perhaps he does, and more power to him for it.
Old May 25, 2007 | 06:17 PM
RPM's Avatar
RPM
Moderator
Here here!
jchamberlain - good luck to you.
Forgive the skeptics.
Keep in mind though that we've heard this a hundred times - from companies and individuals - and no one has got it yet.
Keep us in the know about your progress.
Old May 25, 2007 | 06:26 PM
Thanks all for the input...I will keep you apprised to my progress. Or if I decide to abandon the project altogether...
Old May 25, 2007 | 06:48 PM
saxman's Avatar
Put everything down and go purchase "Maximum Boost" by Corky Bell.
Read it cover to cover several times.
It will help you become much much more educated on the subject, and allow you to make good decisions should you pursue this further.
Remember, even if you find a shop that says they can make a turbo kit for the car, and I'm sure there are plenty that could if they tried, that doesn't mean it would be safe or worthwhile. They key to a successful turbo conversion is lots and lots of knowledge.
Old May 25, 2007 | 06:58 PM
Will do...Thanks.
Old May 25, 2007 | 08:25 PM
NoCones's Avatar
Fine to give a custom turbo or supercharger setup a try if you want, but don't expect it to be a good financial decision. *If* you increase the value of your car, it certainly won't be by as much as the money you'll have to pour into designing/building the system.
Old May 25, 2007 | 08:47 PM
HDDP's Avatar
All very good info for him... But, I think the easiest are the mechanical parts... Now this big problem... The electronics to let your engine run with the upgraded / altered parts...
That's the BIG problem... For the original poster, keep in mind that this car operates on a tangled mesh of computer modules that all have to enjoy each others company... If computer module "A" is having a bad day, the entire car runs the risk of not running properly, or at all...
After doing MEGA research on this process I would not risk it without the professional help of someone who knows exactly how to reprogram the entire computer system... And has proven experience installing a turbo / SC on this engine...
Old May 25, 2007 | 10:36 PM
Maxwell's Avatar
you're right.... has anyone on this forum gone with the kleenman S/C kit... those guys know how to program the car and they have the parts for making boost, too bad they can't drop the price by a couple grand.
Old May 25, 2007 | 11:47 PM
maxxm's Avatar
you're right... has anyone on this forum gone with the kleenman S/C kit, those guys know how to program the car and they have the parts for making boost, too bad they can't drop the price by a couple grand.
You're right, but they will never drop the price because they specialize in tuning MBs for a market that expects to pay those prices (makes everything even more "exclusive," you know). They can get away with price gouging, so that's exactly what they do.
TerryR
Dec 13, 2019 03:27 PM
jimf
Oct 10, 2015 10:22 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Charlesl
Sep 30, 2015 10:46 PM
brandoni
Sep 30, 2015 07:48 PM
