Running temperature
Old Jul 5, 2007 | 08:04 PM
tpredwing's Avatar
Default Running temperature
Had my new roadster (400 miles) out for a ride through a touristy town where traffic was congested. I was surprised to hear a beep alerting me to look at the dash where I found the temp gauge warning. Once I got it moving it did not go off again until a similar driving condition later in the week. Anyone with any comments or similar happenings??
Old Jul 5, 2007 | 08:31 PM
Maxwell's Avatar
Default Re: Running temperature
Is this an '04 model, I'm not sure but you could require a reflash from the dealer on set point at which the cooling fan turns on. Check the TSB section on the forum.
Old Jul 5, 2007 | 08:37 PM
old man's Avatar
it can't be a roadster if it is a '04.
Old Jul 5, 2007 | 08:39 PM
tpredwing's Avatar
'05' Roadster
Old Jul 6, 2007 | 08:40 AM
spensley's Avatar
Is your coolant level correct, and the correct mixture?
Just because the dash doesn't say it's low, doesn't mean it's not.
There was also a recall or TSB on something to do with the fan.
Old Jul 6, 2007 | 02:33 PM
No Warning Shot's Avatar
When my radiator fan went bad my radiator light would come on when the fan should be running at about a tick over halfway on the temp gauge and shut back off after it went down to where the fan would stop running. I never had a beep though.
Old Jul 9, 2007 | 04:24 PM
PAULW's Avatar
There was a recall - Recall E-19 Radiator Cooling fan Module on some models, you can go to
http://www-5.chrysler.com/webselfser...m%28%27R%27%29 to see if your car is involved.
Old Jul 9, 2007 | 05:17 PM
Hopefully yours is covered under the recall. Not all were. Mine went fubar and wasn't included in the recall and they wanted $400 at the dealership for a new fan motor. I said screw it and bought a whole new fan/shroud assembly from eBay for < $200 and did it myself. Only thing that sucked about the aftermarket part though is the plug on the fan wiring doesn't clip tight but it's connected.
roar
Jun 15, 2022 11:46 AM
Nov 11, 2015 05:22 AM
rmcdaniel12
Nov 4, 2015 04:08 PM
amx1397
Oct 2, 2015 05:20 PM
waldig
Sep 17, 2015 10:35 AM
