Spark plugs?
Old Aug 17, 2007 | 03:00 PM
Tazz's Avatar
Default Spark plugs?
Anybody changed spark plugs? Two questions?
1. How big a pain is it ?
2. anyone use a slightly colder plug, especially a Bosch Platinum ???
(thinking about track days here in Phoenix starting in Sept).
Thanks,
Tazz
Old Aug 17, 2007 | 03:43 PM
spensley's Avatar
Default Re: Spark plugs?
There's 12.
Apparently a couple are a real pain.
Do a search, I think you may have to remove some heat shields if my memory serves me correct on something HDDP wrote.
But no, I haven't changed them.
Old Aug 17, 2007 | 04:30 PM
woody's Avatar
The two plugs nearest the bulkhead a real pain and you usually cut yourself on the heat-shields. The plug leads are really tight too so give them a bit of a twist before pulling them off, and don't tug the wires, pull the metal cap. I find the quickest way is to move the coil packs out the way to give you better access, there is no real need to remove the heat-shields and a universal joint on the ratchet helps.
Here are some pics:
Coil packs lifted clear.
These are a PITA, and the ones near the suspension towers.
Old Aug 17, 2007 | 06:43 PM
Sidez's Avatar
Well... I suggest you find a child to do it for you... the small hands will make it a lot easier... also make sure everything is perfectly cool cause it is easy to get burned...
And about the colder plug what is your purpose of changing the plugs...? Is it just time for replacement or do you have performance in mind... ? You can go with Denso IK16 on a stock engine that is about equal to what we have maybe even a little hotter or the IK20 or IK22 if you plan to make modifications that will require a colder plug... but if you are keeping it stock and a replacement choose between the 20 or the 16...
Valk
Jun 22, 2025 09:15 PM
Sterling57
Apr 11, 2016 06:11 PM
Sep 28, 2015 07:40 PM
atdavis2
Sep 21, 2015 01:25 PM
Wisconsinfdcrossfire
Sep 20, 2015 10:04 PM
