Phantom Grip LSD, SRT guys this is for you!
Old Oct 13, 2007 | 01:41 PM
Maxwell's Avatar
Default Phantom Grip LSD, SRT guys this is for you!
I've been watching a thread over on the benz forums, and it seems this company is manufacturing LSD's for SLK32 rear diffs.
I like the price! We'll have to watch and see what the benz enthusiasts think about it.
http://www.phantomgrip.com/product_l...?make=Mercedes
Old Oct 13, 2007 | 01:43 PM
Maxwell's Avatar
Default Re: Phantom Grip LSD, SRT guys this is for you!
How it works.
http://www.phantomgrip.com/how_it_works.htm
Old Oct 13, 2007 | 08:16 PM
LantanaTX's Avatar
Looks very interesting...
Old Oct 13, 2007 | 08:44 PM
apkano's Avatar
Life is random...so am I.
Oh...you're talking about limited slip diffs...
I thought the 60's were coming back!
Old Oct 15, 2007 | 10:19 PM
Sidez's Avatar
if this is true than omg... it is an absolute must for us all... but it is priced way to cheap...
and can you link the benz forum thread...
Old Oct 15, 2007 | 10:57 PM
jonnyangel04's Avatar
Its all over the place on benzworld and mbworld that is the correct pricing they have been putting them in mercedes benz's for awhile now from what I have read.
Old Oct 16, 2007 | 07:34 AM
Maxwell's Avatar
I don't think it's a true LSD coupling, but more like a cheater LSD that acts similar to a clutch style LSD, that's probably why the price is so low, it's cheaper to manufacture than a standard LSD unit.
Old Oct 17, 2007 | 02:08 PM
BLACKSRT-6's Avatar
Has any crossfire tried this? Does any company offer a gear change as well to be used with the crossfire? Thanks.
Old Oct 17, 2007 | 02:16 PM
ShawnQ's Avatar
As for gear changes - there is bound to be another MB product using the same diff housing and same R&P sizes, but in different ratios.
Too much more gear though, and the traction control light bulb will burn out because you'll be spinning the tires more often than not...not to mention you wont be able to utilize the boost as much.
SQ
Old Oct 17, 2007 | 02:26 PM
Maxwell's Avatar
You can swap out the Base gear ratio for the SRT, I forget but isn't the SRT6 a 3.08 gear? And the limited something like 3.45 or 3.70 ish?
I personally would love to have the freeway geared SRT6 ring and pinion in my 6 spd car, 1st gear is a little too aggressive sometimes.
Old Oct 17, 2007 | 03:19 PM
NeverEnough's Avatar
Phantom Grip LSDs aren't some snake oil, fly by night company. They have been around for a while offering less costly choices for LSD and those of us that don't have a true LSD available. I used one in my old Civic SI and worked very well. I would recommend them. And the price they are offering it for is higher than most of their applications I believe, so don't feel bad that you aren't having to pay the MB premium, cause you are. Try it out, I think you'll like it.
Old Oct 17, 2007 | 08:38 PM
LantanaTX's Avatar
Anyone ever see a Quaife or Torsen type dif for our cars?
Old Oct 18, 2007 | 09:31 AM
Maxwell's Avatar
yup, c32 mbz, cost about $1,700 - $2,000 I bet.
Old Oct 18, 2007 | 10:30 AM
Sidez's Avatar
no... does not exist... I have been searching for this product with no luck... the Quaife for the c32 does not fit...
Old Oct 18, 2007 | 12:28 PM
The Phantom Grip is a good product. $500 isn't too bad either. As soon as I get a couple of other "projects" done, I'm going to get one.
Old Oct 24, 2007 | 11:18 PM
xfirecorea's Avatar
Guys, I have a question for you.
Being that the Crossfire Limited ain't exactly a BEAST on the road, I'm wondering whether the Phantom Grip LSD will do anything for a car with about 215 ~ 250 crank horsepower (depending on the tune).
I had always thought that LSD's were for cars that had way too much power for the car's OEM traction to handle.... am I wrong about this? Would a LSD help out 0-60 / quarter mile times of say... a 90 HP Hyundai Accent?
Thanks in advance!
Old Oct 25, 2007 | 06:40 AM
Cincinnati Slim's Avatar
If you're not "one legging it" and doing one wheel burnouts then the factory traction control is doing it's job. A really "tight" posi unit can make a car really oversteer badly on wet roads. I put a Auburn posi-pro unit onto my '97 RWD Cougar and two weeks later backed her into a guardrail on a curving wet entrance ramp when I kicked 'er down trying to accelerate around a curve. $ 1,700 poorer and much wiser ! A Crossfire is a stubby 95 inch wheelbase RWD vehicle without TC/ESP It would want to swap ends on you every time it rained !
Cincinnati Slim
Old Oct 25, 2007 | 08:17 AM
Maxwell's Avatar
It would give you better 1/4 mile times, and the handling on the curvy roads will improve especially if you turn off the TC, have you taken a hard corner at high speed before in a peg legger? If you break traction on that one wheel your totally screwed, and a spin out is imminent and so would be a wreck.
Old Oct 28, 2007 | 07:50 PM
Maxwell's Avatar
found some pix of the phantom grip installed, but it sounds like they are still getting the fitment worked out. anyways something to drool over.
tom2112
Dec 1, 2015 09:02 AM
amatxcrossfire
Jul 30, 2015 08:32 AM
bbsrt6
Jul 12, 2015 09:35 PM
bradleykologek
Jul 6, 2015 02:49 PM
pop49
Australia
Jul 6, 2015 10:10 AM
