Does the NAV still work when disc is ejected?
Old Oct 16, 2007 | 08:08 AM
Haywood's Avatar
Default Does the NAV still work when disc is ejected?
Can the NAV still hold the course and give you directions once the disc is ejected during a route? I read the manual and it doesn't state it. I know some will say, "Well, just check it", but I don't have time. I'm driving to Roanoke tomorrow and if it doesn't, I going to install my XM tonight. I can't deal with local radio! Thanks.
Old Oct 16, 2007 | 08:18 AM
RPM's Avatar
RPM
Moderator
Default Re: Does the NAV still work when disc is ejected?
I believe it does. Once your route is calculated, etc. you can remove the disc (at least I think so).
Old Oct 16, 2007 | 09:05 AM
CrossfireLTD's Avatar
Cool Re: Does the NAV still work when disc is ejected?
Yes you can, the last destination and directions will be held in memory.
Old Oct 16, 2007 | 09:07 AM
eganders's Avatar
Yes. The NAV CD can be ejected and the NAV function will still work. The last several destinations are retained in memory.
The NAV keeps a certain amount of area data in memory, so you can even change routes without reinserting the CD as long as it's local to the area already in memory. As long as you don't disconnect your battery leads, it will retain the info.
If the NAV needs more info, it will display a message asking for the CD again. At that point you can give it a quick update (it takes only seconds), and then remove the NAV CD again.
Old Oct 16, 2007 | 11:05 PM
antonio311's Avatar
As the others have answered, YES it can be removed once the route is stored in the memory.
pioneer4x4
Sep 18, 2023 11:49 AM
PNA
Nov 12, 2020 04:44 PM
Hoppy
Dec 7, 2018 07:36 AM
waldig
Jul 31, 2017 09:46 AM
reiji
Oct 15, 2015 10:50 PM
