Need help on sensor Identification
Old Oct 17, 2007 | 05:06 PM
stallion8797's Avatar
Banned
Default Need help on sensor Identification
Ok, I received the AEM unit and need to wire it up.
Does anyone know what type of crank and cam sensors we have?
Old Oct 17, 2007 | 06:32 PM
LantanaTX's Avatar
Default Re: Need help on sensor Identification
I am not sure of the type but I can tell you where they are. Most likely they are inductive/magnetic. Cam sensor is on front of engine right side above the alternator on the head. Crank sensor is on drivers side top of bell-housing area. Not sure if this helps at all.
Old Oct 17, 2007 | 07:44 PM
Banned
That helps. Now I guess I can figure out the difference between he two and go from there.
Thanks.
Old Oct 17, 2007 | 07:52 PM
LantanaTX's Avatar
I have held them both in my hands before and they appear to be almost the same. just remember which is which and where to find them. you can remove either one with a torx driver.
Old Oct 17, 2007 | 10:37 PM
HAULINAZZ's Avatar
The camshaft position sensor is a hall effect.
The crankshaft position sensor is inductive.
roar
Jun 15, 2022 11:46 AM
rampntlion
21
Feb 11, 2019 08:18 AM
caseydeankopp
Sep 13, 2015 07:25 PM
bobbie
Sep 12, 2015 12:49 PM
2004_
Sep 4, 2015 01:39 PM
