CD Won't eject/Radio says "No CD"
Old Oct 25, 2007 | 08:16 AM
Jeff Cobb's Avatar
Angry CD Won't eject/Radio says "No CD"
When I try to eject the CD that is in the player, it just switches to the radio.
If I try to play the CD, it says "No CD" until I shut off the car.
When I restart, I can select and play the CD just fine, but if I try to eject or switch modes, it goes back to saying "No CD".
Has anyone else had a problem like this?
Would disconnecting the battery help to reset the radio?
Thanks.
Old Oct 26, 2007 | 07:20 AM
Jeff Cobb's Avatar
Default Re: CD Won't eject/Radio says "No CD"
I managed to fix this.
Pulled both radio fuses.
Ate breakfast.
Replaced fuses.
Ejected CD successfully.
Did reset & reloaded NAV CD.
Old Oct 26, 2007 | 07:42 AM
LuvRFire's Avatar
Just out of curiosity, how did you fix it? I had a similar problem where the CD wouldn't eject, but there was a different message on the display (can't remember what it was, though). After I started the car the next time, it was fine and hasn't done it again since.
Thanks.
Old Oct 26, 2007 | 08:01 AM
Jeff Cobb's Avatar
I did have a display problem as well.
Instead of a compass arrow, the right side of my display showed GPS data.
Once I was able to eject the CD, I reset the NAV, put in the NAV CD, and after about 20-30 mins, my NAV and clock had been reset.
All I did to "fix" this was pull the radio fuses (there are two of them) and wait a bit. Once the radio had powered down for a bit, the no eject glitch disappeared.
Hopefully for good.
Old Oct 26, 2007 | 08:37 AM
LuvRFire's Avatar
Thanks, I'll have to remember that fix should it happen again and won't clear...
xfClifford
Mar 3, 2021 04:52 PM
nataliefs
Oct 5, 2015 01:03 PM
Ed Mahoney
Sep 20, 2015 10:35 PM
PA/XFIRE
Sep 5, 2015 01:25 PM
cx24724
Jul 12, 2015 11:57 AM
