Engine stalls when getting to a stop
Old Oct 26, 2007 | 06:50 PM
pabgarmi
Guest
Posts: n/a
Default Engine stalls when getting to a stop
Good evening Crossfire owners:
I just bought an automatic '05 Crossfire Roadster and I have experienced multiple times now that, when getting to a stop, the engine will stall.
It even died three times already.
It is not repetitive and difficult to reproduce. No errors or engine check light show up and the dealer cannot reproduce either.
Is anybody experiencing this same issue? Where you able to solve it?
Thank you in advance for your help.
Old Oct 26, 2007 | 07:26 PM
midnightman's Avatar
Default Re: Engine stalls when getting to a stop
A number of members have mentioned a bit of a near stall while at traffic lights. But not usually a full stall.
It happened to me on two separate occasions within the first month after I bought my new Crossfire two tears ago. The engine sputtered for a few seconds and then was fine.
It never happened again.
Old Oct 27, 2007 | 12:28 AM
bobs's Avatar
You didn't mention how may miles you have on the car, so this is just a guess on my part. You might consider adding a bottle to Techron to a full tank of gas. Could be you have some gunk built up there...
Old Oct 27, 2007 | 08:08 AM
Fenwick223's Avatar
Mine stalled recently but I had experienced random starting issues for the past month or two. Your issue could be the start of the similar problem I and a few others have had. Check the following thread:
https://www.crossfireforum.org/forum...ght=fuel+relay
Old Oct 27, 2007 | 08:11 AM
Are you using premium fuel? Low octane fuel can make it stall.
Old Oct 27, 2007 | 01:03 PM
mousegu's Avatar
Could be the throttle body is full of crap... Take it off, clean it out put it back on.
Go to a local autozone and get fuel injector cleaner. You put it in your gas tank, then drive around for awhile. Make sure you floor it often (shouldn't be a problem eh?) oh clean things out...
It could also be a vacuum leak. Does it idle harshly? Low or bobbing?
Old Oct 27, 2007 | 03:04 PM
LantanaTX's Avatar
The one problem that is very common with these engines is the crank position sensor going bad. The early symptoms of one going bad is stalling when you come to a stop light. The engine will quit just as you come to a complete stop. the next symptom is the engine will not immediately re-start, may restart after 5 15 minutes. This is new problem for Crossfires since out cars are now getting old enough to see this happen. My old car was a 2001 ML320. Since these engines have been around since 1998 the MB guys are very familiar with this problem.
The sensor is very easy to replace yourself but dealers will want a lot more.
Old Apr 4, 2008 | 11:32 AM
TiamoPhoto's Avatar
where is the CPS located and does Autozone carry it?
Old Apr 4, 2008 | 02:24 PM
kurtisberry's Avatar
Any leaks in the air intake will cause this. Check all connections.
skeet370
May 15, 2018 12:57 PM
jgreen
106
Sep 18, 2017 11:46 PM
northwest_crossfire
May 30, 2016 05:19 PM
waldig
Sep 2, 2015 11:02 AM
skeet370
Aug 2, 2015 01:41 PM
