Help! I broke one of the airbox screws!
Old Jan 18, 2008 | 04:33 PM
CBXFIRE's Avatar
Default Help! I broke one of the airbox screws!
So this afternoon I made a foolish mistake by trying to rush the install of new air filters... For whatever reason I thought I recalled there only being three screws... so I unscrewed the three screws and pulled on the cover and POP the fourth screw i didnt remove broke off with the plastic drive hole from the cover still attached!!
I went ahead and changed the air filters with the K&Ns i purchased and replaced everything as normal. There is a slight gap in the outer edge of the side that broke off... But i dont think its large enough to let anyting through.
So I have several questions, I'm hoping someone can help answer...
Is it ok to continue to drive with one of the screws not attached? I assume as long as i dont drive in the rain i should be ok?
How much does a new cover cost? I looked on ebay but couldnt find one.
Is there a way to repair the cover or am i stuck buying a new one?
Does this present a good time to upgrade the intake given my need for a new cover? I still have the powertrain warranty and I'd like to keep it that way...
Any and all suggestions would be greatly appreciated!
Note to self... dont try to rush things after a long day of work!
Old Jan 18, 2008 | 04:47 PM
amick6534's Avatar
Default Re: Help! I broke one of the airbox screws!
One just sold on E-bay a couple of days agoe for $99.00 But it is rare that you can find one on there. That was the first and only one I had seen.
Old Jan 21, 2008 | 05:15 AM
spensley's Avatar
Without seeing the broken area it's hard to make a firm suggestion.
However, look at whether you can use a longer screw, or bigger diameter. You may have to do some drilling, but it's cheaper than $100 on ebay.
Old Jan 21, 2008 | 06:41 AM
maxcichon's Avatar
Is there enough of the shaft from the broken screw exposed to use a small tap handle to grab it? You can turn it out using this tool if there is.
Old Jan 22, 2008 | 11:08 AM
CBXFIRE's Avatar
Thanks for the replies... I'll try to get some pictures up this week.
I'm pretty sure i can get the screw out its just figuring out how to secure the corner. I'll take a look at drilling a new hole when i take the cover of for the picture shoot.
RamblinShamblin
Aug 12, 2017 10:55 PM
Dgiomatch1
Sep 20, 2015 01:05 AM
jaesa
Sep 7, 2015 01:50 PM
ldare2000
Aug 17, 2015 09:41 AM
DKAwildcat
Jul 17, 2015 04:58 PM
