Factory amp or aftermarket?
Old Mar 7, 2008 | 11:29 PM
snowtop57's Avatar
Default Factory amp or aftermarket?
Ok, I just received my new headunit from Crutchfield, a Blaupunkt St. Louis, and it came with a free Blaupunkt 2
channel 60 watts RMS x 2 at 4 ohms (80 watts RMS x 2 at 2 ohms). Although I don't know what all that stuff means.
Would I be better off just keeping the factory amp or should I replace it with this free one I got? I'm not much of an audio buff, but I knew that the factory radio had to go. The sound is not all that great & the navigation unit pretty much sucked and I have a portable one to use anyway.
Old Apr 26, 2008 | 03:44 PM
beto7650@yahoo.com's Avatar
Default Re: Factory amp or aftermarket?
HI....DID YOU INSTALL THE RADIO...? DID YOU BYPASS THE AMPLIFIER... IF YOU DID...SELL IT TO ME.... MINE IS FRIED...AND I NEED ONE.... THANKS..... BETO7650@GMAIL.COM
Old Apr 26, 2008 | 04:05 PM
Voyager's Avatar
well from what ive been told the stock amp is 250 watts. i have not seen it and im not entirely sure that is even true but if it is then it sounds like the factory amp is bigger. you could wire them in series and use both i guess to. that is of course if the factory amp is capable. but what are your plans with the stock nav headunit. you selling it? cause am looking for one
Old Apr 26, 2008 | 07:26 PM
snowtop57's Avatar
I was able to keep the factory amp, everything sounds great. Sorry I can't help you.
Old Apr 26, 2008 | 07:27 PM
snowtop57's Avatar
I plan on keeping the factory nav head unit so that I can reinstall if & when I get rid of the crossfire.
syfi
Mar 28, 2026 04:14 PM
usprb1976
Apr 4, 2024 04:57 PM
Sterling57
Apr 11, 2016 06:11 PM
Blackktieguy
21
Oct 26, 2015 12:32 AM
mobilefitt
Sep 24, 2015 01:04 PM
