90 Degree Hood
Old Mar 27, 2008 | 06:42 AM
smokey847's Avatar
Default 90 Degree Hood
So I did a search on how to open the hood to the full 90 degrees, but no luck. Any help?
Thanks.
Old Mar 27, 2008 | 07:11 AM
RMADERMAN's Avatar
Default Re: 90 Degree Hood
Thanks.
There is a button on the upper backside of the arm holding up the hood. Press it and it will go up to 90 degrees.
Maybe someone will show you a picture. Andrew is good at that.
Old Mar 27, 2008 | 08:49 AM
smokey847's Avatar
Ok. Just tried it. Thanks!
Old Mar 27, 2008 | 08:51 AM
apkano's Avatar
Life is random...so am I.
Just so you know.......there's a button on the bottom of the cylinder that lowers it.
You don't use the same button to go down.
Old Mar 27, 2008 | 08:58 AM
smokey847's Avatar
Yeah, thanks. I discovered that after having a minor panic attack when I couldn't get my vertical hood down. Ha ha.
Old Mar 27, 2008 | 09:03 AM
apkano's Avatar
LOL.......I had a thought that would happen!
Old May 22, 2008 | 05:02 AM
Highlander's Avatar
Cool! I am learning all kind of neat tricks!!! Now if I can only find the slot that kicks out the $100 bills!!
Old May 22, 2008 | 05:08 AM
Opticon's Avatar
Actually you do.
Old May 22, 2008 | 05:54 AM
apkano's Avatar
Originally Posted by Opticon
Actually you do.
Maybe yours is special......I have one button on the top of the cylinder to go up, and one on the bottom of the cylinder to go down.
Old May 22, 2008 | 05:57 AM
danimal's Avatar
You guys are cracking me up.........LOL. The button stays in the same place...the outer sleeve slides up (or down).
Old May 22, 2008 | 06:35 AM
+fireamx's Avatar
90 degree Hood? Sounds "HOT" to me.
Sorry, I couldn't help myself.
Old May 22, 2008 | 07:32 AM
Opticon's Avatar
When I push the gas pedal... the earth moves backwards.
Old May 22, 2008 | 08:15 AM
danimal's Avatar
Go the other way and see what happens........
Old May 22, 2008 | 08:18 AM
Opticon's Avatar
The trees are passing me! I'm afraid one is going to rear end me.
Old May 22, 2008 | 04:56 PM
KrzyFast's Avatar
I never knew about this! I just went out and tried it. The is Freaking AWESOME!
This car amazes more and more each day.
On the flip side, I am going to hate to replace that particular strut when it finally goes bad... It is probably $150+. But is is very cool.
Thanks for sharing!
Cheers,
KrzyFast
8ighth Wonder
Dec 15, 2015 01:42 PM
Charlesl
Sep 30, 2015 10:46 PM
waldig
Sep 17, 2015 10:35 AM
Vegaslegal
Sep 10, 2015 11:24 AM
RiderJC
Sep 7, 2015 11:19 PM
