'04 Manual Coupe with Flowmaster 40 Delta Series
Old Apr 8, 2008 | 06:35 PM
dkniess's Avatar
Default '04 Manual Coupe with Flowmaster 40 Delta Series
So, I had a Flowmaster 40 Delta Series installed last weekend. I think it sounds pretty good, but the resonance inside the car between 2,000 and 3,000 rpm is pretty bad. I'm going to try installing some dynomat in the trunk area to see if I can reduce the resonance. If that doesn't work, I'm going to swap out the Flowmaster for a Magnaflow. The first video here is a launch to about 80mph and the second video is a start up followed by some revving. Hopfully the links will work.
http://www.youtube.com/watch?v=RHBDVD2hFBo
http://www.youtube.com/watch?v=o97jxyhNKrM
Old Apr 8, 2008 | 07:22 PM
MAYAman's Avatar
Default Re: 04 Manual Coupe with Flowmaster 40 Delta Series
I don't understand, are you ge3tting rid of someting from the stock exhaust that keeps the noise inside the cockpit down?
Old Apr 10, 2008 | 03:51 PM
hemifire's Avatar
Default Re: '04 Manual Coupe with Flowmaster 40 Delta Series
I have no muffler and I used dynamat across the back of the trunk(between tail lights) to cut the noise down. Works pretty well.
Old Apr 12, 2008 | 07:53 AM
dkniess's Avatar
Switched out the Flowmaster muffler for a Magnaflow today. It's a much better sound, much less resonance inside. It sounds like it belongs on the car. All is good. Anyone interested in the Flowmaster muffler? If you like it loud, it's for you. I will sell it dirt cheap.
Old Apr 12, 2008 | 08:11 AM
Shawnkey's Avatar
Can we get some audio of the magnaflow? Also, what type of mag did you put on there?
Old Apr 13, 2008 | 11:03 AM
dkniess's Avatar
I've had the Magnaflow muffler on the car for a little more than 24 hours. I have fallen in love with the Xfire all over again. After I had the Flowmaster installed last weekend, I felt like I had turned my Xfire into a V6 Camaro, but now with the Magnaflow I think it's just right. Now, I believe that most people have the Magnaflow Cat-Back system. I just went with the muffler. The part number is 12158. I told the guy at the exhaust place that I thought most of the members on here had part number 14420, but he was sure that 12158 would work better. They got it installed with the factory tips and I can't argue with him. The biggest difference is inside the car. I can now listen to the radio again or talk to my wife between 2 and 3,000rpm. We went out this morning and blew about 5 bucks worth of gas making videos. Muffler and labor cost about $200. I want to say that it feels like it pulls just a smidgeon harder above 4,500rpm. Here are the links to youtube!
Revving - http://www.youtube.com/watch?v=vP-_V2Z7VuQ
0-80mph - http://www.youtube.com/watch?v=qZJmmBG4enI
Drive by 1 - http://www.youtube.com/watch?v=6UXpXLnfAe8
Drive by 2 - http://www.youtube.com/watch?v=OVL9S967e4s
Inside (brisk acceleration) - http://www.youtube.com/watch?v=DJKVfYVC2h8
Inside (moderate acceleration) - http://www.youtube.com/watch?v=XZZ-EvbsbDM
Old Apr 13, 2008 | 12:51 PM
GDrag's Avatar
Thats awesome!
I've been wondering for the longest time if it's going to be too loud, or to quite. Seems like the magnaflow is the one for me!
Old Apr 13, 2008 | 01:20 PM
modulator's Avatar
Banned
Yes, Thanks very much for the time and trouble to make the videos and write this post. I have been considering changing exhaust to get just a little more aggressive and racier sound from my 04' 6spd. - didn't want to waste a lot of $$$ getting something I wasn't happy with. Your's seems to have the sound I'm looking for...
Old Apr 13, 2008 | 05:25 PM
tashspop's Avatar
i agree, that sounds awsome.
Old Apr 15, 2008 | 04:40 PM
Shawnkey's Avatar
was it 2 1/4 in or 2 1/2 in?
Old Apr 15, 2008 | 07:07 PM
dkniess's Avatar
I'm pretty
Old Apr 15, 2008 | 07:08 PM
dkniess's Avatar
no damn it, I'm not pretty. I'm pretty sure it was 2 1/4.
Old Apr 17, 2008 | 08:23 AM
itsky's Avatar
Thanks for sharing. Sounds very good!
Old Apr 17, 2008 | 08:43 AM
itsky's Avatar
Sorry if this sounds like a noob question, but did you just replace the muffler or did you replace anything else with it? I'm seeing that muffler online for $85-$115. Probably have it installed at a local muffler shop.
Old Apr 23, 2008 | 12:10 PM
modulator's Avatar
Banned
[quote=dkniess]I've had the Magnaflow muffler on the car for a little more than 24 hours. I have fallen in love with the Xfire all over again. After I had the Flowmaster installed last weekend, I felt like I had turned my Xfire into a V6 Camaro, but now with the Magnaflow I think it's just right. Now, I believe that most people have the Magnaflow Cat-Back system. I just went with the muffler. The part number is 12158. I told the guy at the exhaust place that I thought most of the members on here had part number 14420, but he was sure that 12158 would work better. They got it installed with the factory tips ...
Question- What did they do in the way of fabrication to make this muffler fit???
Old Apr 23, 2008 | 12:32 PM
dkniess's Avatar
They shortened the pipe from the cat to the muffler, because the Magnaflow is longer than the stock muffler. Also, they cut the tips completely off of the new Magnaflow and welded bigger diameter pipe onto it so they could properly fit the stock tips on. They charged about $70(US) for the labor.
Old Apr 23, 2008 | 12:35 PM
dkniess's Avatar
Yes, just the muffler was replaced. We just went on a several hundred mile cruise this past weekend with a bunch of other Crossfires owners and everyone seemed to really like it.
If you don't want the stock tips welded back on, it's a lot less work. My shop spent about 90% of the time getting the tips on. It's a lot of work, but possible if they know what they're doing.
Old Apr 23, 2008 | 02:04 PM
modulator's Avatar
Banned
I wish I lived where you do because the pipe back to the cat not only needs to be shortened, it also requires bending- the stock muffler has a side inlet while this muffler is center inlet.
crossfiren00b
U.K.
Aug 18, 2015 01:58 PM
itsky
Aug 9, 2015 07:39 PM
itsky
Aug 1, 2015 03:45 PM
Bifftws
Racing
Jul 28, 2015 05:31 PM
Dave Wilson
Jul 18, 2015 05:31 PM
