On board oil level indicator
Old Apr 14, 2008 | 11:59 AM
Montana Crossfire's Avatar
Red face On board oil level indicator
Has anyone had trouble getting their onboard oil level to come on in the alotted time.
I couldn't always get mine to come on in my Limited and I have yet been able to on the SRT.
Any tricks to make it easier?
Needn't tell me I shouldn't use anything other than the dip stick. It's just I would like to check it everytime I drive it.
Thanks for any input.
Old Apr 14, 2008 | 12:12 PM
spensley's Avatar
Default Re: On board oil level indicator
Not sure what you mean by 'Come on in the allotted time"
Old Apr 14, 2008 | 12:37 PM
Well within the several seconds that one has to push the putton
Old Apr 14, 2008 | 01:16 PM
spensley's Avatar
Which button - the one on the dash?
Old Apr 14, 2008 | 01:19 PM
Maxwell's Avatar
no trouble here, but it reads half a qurart too low
yes the one on the speedometer
Old Apr 14, 2008 | 01:33 PM
Yes the one one the Speedo
Old Apr 14, 2008 | 02:46 PM
Rusty Monroe's Avatar
I had mine pop up once after I reset the FSS, now I can't get it to show at all....
Old Oct 20, 2009 | 02:00 PM
2005 Ragtop's Avatar
All,
Was there ever any resolution to this ???? Never attemted prior to FSS schedule A maintenance. Using procedure on page 111 of 2005 Owners Manual = NO JOY.
Old Oct 20, 2009 | 04:57 PM
maxcichon's Avatar
Keep trying-it can be a bit fiddly.
Old Oct 20, 2009 | 05:18 PM
Bladecutter's Avatar
Originally Posted by 2005 Ragtop
All,
Here's the procedure:
CHECKING ENGINE OIL LEVEL
A sensor in the oil pan allows oil level to be checked without opening the hood.
It provides an accurate measurement of oil level, whereas the low engine oil level indicator warns that oil level is definitely too low.
With the vehicle parked on a level surface, the engine is warmed up and shut off for approximately five minutes.
When the ignition switch is turned to the ON/RUN position, press the **** to the left of the speedometer once and wait seven seconds.
An ISO oil level icon appears in the trip odometer window and a “clock” icon in the cumulative odometer display.
Pressing the **** to the left of the speedometer twice within one second displays one of the following messages:
˛ OK
˛ -1.0 Q (-1.0L)
˛ -1.5 Q (-1.5L)
˛ -2.0 Q (-2.0L)
˛ HI
The indicated amount of oil must be added to the engine
if the message -2.0 Q (-2.0L) blinks and a signal sounds.
The HI message indicates that the excess oil must be removed from the pan to avoid possible engine or catalytic converter damage.
If the ISO oil level icon and “clock” icon remain on when attempting to check oil level and no message follows, or if the low engine oil level warning lamp comes on, a malfunction in the engine oil level system is indicated.
A conveniently located dipstick allows manual checking of the oil level.
If no leaks are noted, continue to drive to the nearest service station where the engine oil should be topped to the “full” mark on the dipstick with an approved oil.
BC.
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
eikon
Sep 9, 2019 10:16 PM
o55ie18
Oct 5, 2015 05:50 PM
Sep 28, 2015 07:40 PM
