"High Oil" light
Old Apr 19, 2008 | 12:34 PM
Default "High Oil" light
Just got back from getting the oil changed at the dealer. When pulling up to the house, the High Oil light came on. I assume this means they put in too much oil. Should I do anything or will it burn off the excess?
Old Apr 19, 2008 | 01:05 PM
iuhoosiers's Avatar
Default Re: "High Oil" light
it says right on the oil cap that too much oil can damage the engine. i would go back to the dealer and make them check it out. remind them that it takes 8.5 quarts. maybe they added nine.they will certainly have some sort of topsider which would make it easy for them to suck some out.
Old Apr 19, 2008 | 05:21 PM
Actually when I change my own oil and filter 8 quarts even fills her right to full on the stick. This reading is after the car is run,warmed up and off for several hours. It also reads OK on the cluster.
Oil will not burn off and may do damage if left overfilled.
Old Apr 21, 2008 | 10:35 AM
Well, the wife went by the dealership on her way to the office this morning. 45 minutes later she got the car back with the excess oil removed. What a hassle. I'm now in the market for a topsider to change the oil myself (which I used to always do on previous cars).
Old Apr 21, 2008 | 02:18 PM
patpur's Avatar
Senior Member/Moderator
The same thing happened to our Mercedes. We ended up taking it back to the dealer to either drain or fix the sending unit. My Crossfire did it right before the last oil change. Quite frankly I like the idea of a dipstick, I mean how freakin hard is it? Glad you are squared away.
Pat
Old Apr 21, 2008 | 05:02 PM
Mabs's Avatar
this just happened to me 2 days ago. I took it back and they drained an extra 2 quarts out of my car. I ended up getting my money back
Old Apr 21, 2008 | 06:33 PM
2 quarts over? Wow! Our receipt showed they put in 9 quarts. I figured they rounded up from 8.5 quarts. I wasn't going to quibble over the cost over the cost of a half quart. But this experience does make me want to start getting back into changing the oil myself.
Now, topsider or draining it from the bottom? There are lots of good points on each side of this subject here (after doing many searches) but I've still not decided which way to go.
Old Apr 21, 2008 | 06:45 PM
corfire's Avatar
I have also found that 8 quarts seems to be plenty, filling the dip stick to the full mark.
Old Apr 21, 2008 | 07:47 PM
+fireamx's Avatar
I only put 8 qts. in mine when ever I change it. Never had any problems. It's usually better to be a little under than over when you're talking oil.
Old Apr 21, 2008 | 09:37 PM
Mabs's Avatar
after that experience I am never going to take my car anywhere but my garage for an oil change. I prefer draining from the bottom.
Old Apr 22, 2008 | 03:12 PM
a12rag's Avatar
I agree . . . change the oil yourself if you can !! It is way too easy to do. . . hardest thing was getting the belly pan off to get to the oil pan and drain plug !! Love how easy the filter is to take out and replace. No way I am going to pay the prices they want at the dealership or oil change place when I can do it for less - using MOPAR(Mercedes) oil filter and Mobil One, still about $30-40 less !!! Only 1 hour out of my day (at the MOST) and best of all, get to play with my baby !!!
Mark
04, 6spd
Old Apr 22, 2008 | 04:39 PM
huudoo's Avatar
8.0 qts works for me
Old Mar 11, 2009 | 03:48 PM
Kit Fox's Avatar
What kind of damage?
Old Mar 11, 2009 | 04:16 PM
maxcichon's Avatar
If the level is high enough in the pan, the crankshaft will contact the oil and whip it into a froth-think CoolWhip. This can't be pumped, so you will run with the same thing as a dry sump-no oil circulation. No Bueno!
Old Mar 11, 2009 | 04:41 PM
nate_man's Avatar
When you change oil in a car without it the pan being dropped there is still a bit left in the engine. A brand new engine takes the 8.5 but when we do changes we dont get every ounce out so its a little over 8 to refill.
Old Mar 11, 2009 | 07:36 PM
VQ35DE's Avatar
8.0 quarts for me.
Old Mar 12, 2009 | 07:50 AM
2006 Roadster in TN's Avatar
I bought a Topsider and I tried it on my worn out daily driver first.
I hated it.
I drain from the bottom. Gives me a chance to check everything under the car while I'm down there anyway.
8 qts and drive for a few days, check it, add any as needed.
Old Mar 12, 2009 | 10:22 AM
MikeR's Avatar
I used the topsider type(hooked up to my compressor) and when I refill it take 8.5 quarts. I put in 8 and run it to get things circulated and then shut it off and let it set and re-check the dipstick. Then top off.
MikeR
Old Mar 12, 2009 | 01:13 PM
PhillySRT's Avatar
Same thing happened to me a couple months ago. They put in 8.5 quarts and had to take out 1/2 quart when I took it back. I checked it a week later and it was filled to the top of the dip stick. Odd, since pretty much every reference I can find says that it takes 8.5.
wootto
U.K.
Aug 16, 2020 07:55 PM
PimpDaddy
Mar 31, 2020 07:22 PM
Danyuhl
Nov 2, 2019 05:18 PM
pioneer4x4
Aug 9, 2015 08:15 AM
ricardo 53
Jul 21, 2015 07:49 AM
