Another AMP Question
Old May 2, 2008 | 07:45 AM
btfpro's Avatar
Default Another AMP Question
A little history.
1. I have already installed a Kenwood X791 head unit with Sirius, Ipod and Bluetooth.
2. Also a false floor in the trunk with a separate Ultimate amp with a Blaupunkt Low Profile sub. I am very happy with the bass and it does not take up to much trunk space.
3. I am NOT happy with the front speakers, they seem to be very muddy and not as clear as I would like them.
1. Should I just replace the front speakers with something like the Infinity Kappa’s and leave the OEM amp alone.
2. Should I replace the amp and speakers, and maybe disconnect the rear (behind the seat) speakers? Since the bass is already being handled by the 10” in the trunk.
Old May 2, 2008 | 08:00 AM
khanable's Avatar
Default Re: Another AMP Question
Out of curiousity have you done the capacitor mod for the door speakers? They clean themselves up rather nicely after that mod...
edit: I would start with replacing the speakers alone if you do not like them. Make sure to look up the specs on them and whatnot before you shell out big bucks for speakers that may not work.
If you are still unhappy, move to pulling out the old amp and getting a new one.. perhaps to power just the sides or even to power the backs as well.
if you'd be spending that kind of money anyway, why not spend as little as possible (just the speakers) and then move up?
Though, if you haven't done it, the capacitor mod is all of $5 bucks and two beers. That'd be my first try. Followed by speakers, and then possibly by a new amp and old/new back speakers, etc.
Old May 2, 2008 | 08:03 AM
btfpro's Avatar
Yes, I did that mod. Still not happy with the front speaker setup. Not sure if it just a power issue or a speaker issue.
Old May 2, 2008 | 08:04 AM
khanable's Avatar
added more to my post see above you
Old May 2, 2008 | 08:33 AM
btfpro's Avatar
I guess the problem with just changing the speakers, if I get this right, they are 2 ohm and if I change the amp also, I would switch to a 4 ohm system.
I believe it is 2 ohm because they are joined with the back subs.
TerryR
Dec 13, 2019 03:27 PM
jimf
Oct 10, 2015 10:22 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Charlesl
Sep 30, 2015 10:46 PM
brandoni
Sep 30, 2015 07:48 PM
