Question about oem ic pump
Old May 19, 2008 | 05:00 PM
robby363's Avatar
Default Question about oem ic pump
I replaced my ic pump with the Johnson pump today and does anyone know what the vacuum line or hose is for on the oem pump?
Old May 19, 2008 | 05:44 PM
robby363's Avatar
Default Re: Question about oem ic pump
Did anyone else have a vacuum line on the oem ic pump? The service manual doesn't say anything about it and I haven't read anything on here about it either. But mine had one connected to it on the same end the wire harness was on.
Old May 19, 2008 | 05:45 PM
70GT6's Avatar
Mine had one (well a hose, not sure if it was a vacuum line or not)
I just plugged it.
I used the Cobra/Lightning pump which did not have the connection either.
Old May 19, 2008 | 05:50 PM
robby363's Avatar
I just plugged it.
I used the Cobra/Lighning pump.
Thanks I plugged it to. but I hope it doesn't go to anything important.
Old May 19, 2008 | 05:59 PM
70GT6's Avatar
Well....it went to the IC pump. j/k
Why..no clue.
Old May 19, 2008 | 06:04 PM
70GT6's Avatar
delete.........
Old May 19, 2008 | 07:10 PM
Maxwell's Avatar
possibly an air purge line? I did post a link a long time ago on how to purge the air out of the IC system, it's located over on the mbz forum.
Old May 19, 2008 | 07:12 PM
70GT6's Avatar
Seems unlikely. It is at the back of the pump near the electrical connection - motor side not impeller side.
Maybe????
Old May 20, 2008 | 08:20 PM
PA/XFIRE's Avatar
Thumbs up Re: Question about oem ic pump
Hi Maxwell When i changed my pump i traced that line up into the motor compartment it dead ended .I assumed it was for purging air out of the i/c system too.I would like to know how to purg the i/c system,i'll see if i can find it on the mbz forum. ILLCYA
gblack32
Sep 7, 2016 08:27 PM
Soma
Dec 14, 2015 07:52 PM
BrenLW
Aug 5, 2015 04:53 AM
axnguyen
Jul 21, 2015 11:41 AM
